Question about HP LaserJet 1022n Printer
HP Laserjet 1022
When printing, the ink on the paper comes out dark on both sides, or one side or in the middle. It does not matter if you try to print a long document to get rid of the "smears" it happens all the time. I think it comes out dark due to excessive ink release.
  • peridot8 Jul 08, 2008
    Our HP 1022 has a black line on the left side of the page. I changed the toner cartridge and it was fine for a number of printings. Now the black line is back and increase in darkness with each printing.
    Problem Solver:
  • 8 Answers
One thing you can do is take out the toner of the printer rock back and forth and side to side, just slightly to distribute the toner this sometimes fixes the printer issue.
Posted on Mar 06, 2008
  • 417 Answers
Have you refilled the toner cartridge or is it refill as when these toner cartridges are refilled they have a tendency to leak. I suggest to remove toner cartridge turn the machine off vacuum out the inside and replace the toner cartridge with a new original. Run 20-30 prints through to get rid of any other loose toner and then should be fine.
If printing doesn't improve then repeat process if still same problem suggest transfer roller to be changed.
Hope this helps
Thanks J
Posted on Jan 13, 2008
How to do borderless printing on HP laserjet 1022n?
the hp 1022 is not capable of printing edge to edge for that matter very very VERY few can. the problem is that the printer needs to be able to move the paper through the machine without distorting the printed image and this requires a LEAD EDGE usually about 3-5mm edge to edge down the long side of the paper the printer is able to get quite close to edge at 2-3mm either side but NOT EDGE to EDGE the only real way of accomplishing true edge to edge is to overprint and trim the final page to size.e.g. print on A3 and cut to A4
Jan 29, 2014 | HP LaserJet 1022n Printer
HP Laserjet 1022 orange light keeps flashing
1. Check any paper jams in side.
2. Check cartridge.
3. Remove back cover, clean paper sensors.
4. Replace Formatter board.
Jan 05, 2013 | HP LaserJet 1022 Printer
My HP printer 1022 laser jet is making black stripes at left corner of the paper
This could happen due to
1. Worn wiper blade
2. Worn Drum
3. Worn PCR
above 3 are inside the toner, if you know how to replace them replace or install a new toner, if the problem still persists you have to check the fuser or contact a technician..
Jun 20, 2012 | HP LaserJet 1022 Printer
Triagle light blinks on HP Laserjet 1022
If only the triangle light blinks then is because one of the following reasons:
1.The print cartridge door is open.
2.The printer is out of paper.
3.The print cartridge is installed incorrectly. Try opening the door, removing the cartridge and installing it again. It should snap into place.
4.There is a paper jam. Remove the cartridge and check if there is a paper jam.
Feb 06, 2010 | HP LaserJet 1022 Printer
Dark line is printed on the right side of every
Most likely this is the drum. Take a damp cloth and clean the top of the drum roller. This should fix the problem. Good Luck.
Oct 27, 2009 | HP LaserJet 1022 Printer
How can I make my laserjet prints look as dark as my designjet pr
It si not possible because the %darkness of the black ink and the black toner. The first is near 93% black and the toner even at ***** eye looks dark gray less than 90% black.
Jan 12, 2009 | HP DesignJet 4000 InkJet Printer
HP Laserjet 1022
on the back side thers are two papers sensors inside the printer,they get stucked,normally they should come back
Jan 23, 2008 | HP LaserJet 1022 Printer
HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
Dec 31, 2007 | HP LaserJet 1320 Printer
Problem with printing with HP 1022 laser printer
Hi, Laserjet 1022 printe supports printing through the Laserjet 6L drivers and its tested, please select the same USB port for the Laserjet 1022 printer which is selected for the Laserjet 6L printer and then try printing. Ragards, MukeshS
Aug 18, 2006 | HP LaserJet 1020 Printer
HP LaserJet 1022n Printer Logo
196 people viewed this question
Ben Johnson
