Question about Refrigerators
Temperature too cold even when on lowest
Temperature is too cold even when on lowest setting...veggies are freezing
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Jul 12, 2009
Model SJF750SP. Refrigerator temperature 6 degrees Celsius. Why does everything freeze, even veggies in the veggie bin?
First try adjusting the thermostat inside the refrigerator to a lower number. If this does not work, you have lost some refrigerant from the system, due to a leak. The system would then need more refrigerant installed to correct the freezing problem and repair the leak.
Oct 19, 2015 | Sharp Refrigerators
My Maytag Dual Pro top freezer is running too cold.
freezer should be -15 and that is about 4-5 c on the knob
fridge should be around 4-5 C which is around +3 C
frost build up is from door opened too often , for too long or bad door seals
It is more prevalent when the ambient humidity is above 50% as it is the water vapour in the air condensing on the cold surfaces
Dec 13, 2017 | Refrigerators
I have a Norcold n611 fridge gets too cold and freezes even on lowest setting.
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 10, 2012 | Thetford Norcold RV Cooler/Freezer
The temperature in fridge is too cold even w/dial turned to the lowest setting. What is the red button on dial for
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Sep 21, 2011 | Refrigerators
The vegetables in the bottom drawers of the refrigerator are being frozen. What an I do to resolve?
Veggie can freeze easy when temps are incorrectly set within the unit. Check temperature setting for both sides of the unit. Due to physics cold air drops and heat rises. With this in mind, make sure door seals are tight around the doors, if this does not solve the problem, you may need to cut off the direct air flow into the veggie bin directly to solve this issue. Over the years I have seen reducing air flow calms the freezing issue.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 11, 2011 | Samsung RS2534 Side by Side Refrigerator
Milk, lettuce freezes after temperature is reduced
turn both control to the same number the lowest number and then wait 24 hrs if you want it needs to be cooler move both controls 1 number then wait 24 hrs and see if you are happy
Apr 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
My refig keeps freezing items in the veggie bins and even above that
Lower the settings to 1 or 2. If you have veggie bins with the sliding adjusting air vent (door thingy) check them and make sure the settings are cold and not colder. it brings more air to the bottom. Cold air drop to the bottom because it is heavier than warm air.
Mar 30, 2010 | Refrigerators
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Crisper and veggie bins are freezing the produce
I have dealt with bosch and thermador quit a bit and they usually don't have to much of a recommendation for these settings because they are more of a commercial type appliance producer and all situations are different. Here is a tip for the sliders though. Remember that leafy produce needs more airflow to hold its texture and taste and anything with a skin requires less airflow. As far as the temp settings I believe the most nominal settings are going to be in between 5 & 7 to keep from freezing the produce. You will have to play around with it a little though to get it to keep the ref good and cold but keep from freezing the vegies. Hope this helps. Good luck.
Jun 05, 2009 | Bosch KGU6655
Veggies freeze up in the compartment meant for them
1 is the warmest setting, 7 is the coldest.
No answer for your veggies freezing.
Jan 09, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
673 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
