Question about Boating
Motor is dead - Boating
  • ssallese Jul 14, 2009
    Maybe I can just **&#^&#*and then I can take the F*&#%#^
  • 57 Answers
Wrap a rope around its leg and throw it off the back-make sure you hold onto rope tightly-you now own a new anchor! lol
Posted on Jul 13, 2009
2002 mercury cougar make a clicking noise like the battery is dead but it's not and won't jump start either.
Are you sure the battery is not dead? This is usually a good indicator of a dead battery or not enough charge to turn it over
Failing that Loose leads,Poor connection to starter motor or faulty starter motor.
Oct 15, 2016 | Mercury Cars & Trucks
Wipers only work on slow intermittant
front or rear, guess front... gee?
you meant fails only on high and fails means dead, rigth, not slow on high or some other odd effects. like noise. chattering or ?
what does it do on high , i guess sits still.
the wipers can be slow. if the motor is weak.
fail to return
make noises. or jam.
Q1:" do the washers work
2004 WJ
there are 3 things, POWER< CONTROLLER and MOTOR.
the first question here, is this computer controlled (eg BCM)
answer: YES, the BCM does keep alive. (more later)
is there a relay?
answer yes.
the control has 10 position.. off 1....9
so intermattant 1 to 5 work, you never said that.
at pos. 6 is low, works.
at post 7 high its dead. it turns on the HIGH wiper relay in the PDC
so that is dead,
my guess. i use meters to tell me facts but if i hand to guess
it be the HIGH relay blown.
if not its the H tap pin on the motor bad.
or wires to same.
the wiper motor can be hot wired to test it. easy
pin 6 on the motor connector is hIGH./
if how ever the high starts the wiper moving and then dies
then the PCM keep alive feed is dead. or wiper on./off is dead.
but the other work, so id skip this.
try to say exactly what happens on high. (DEAD?)
OR MOVES AND STALLS.? O short strokes.?
Jan 03, 2016 | 2004 Jeep Grand Cherokee
My power window will not work is there a fuse that controls all windows
There is a fuse for windows. However, if only one window is non operational, there is either a short specifically affecting that window or the motor for the window is broken.
Dec 08, 2015 | 1996 Jeep Grand Cherokee
What could be wrong,My pump wont turn on , it makes noise but wont kick on
open it up and see if the impeller will turn freely when it is disconnected from power. Call pool guy or pool store and see if it just needs a solenoid.
Sep 19, 2014 | Hayward 1.5 Hp Northstar High Performance...
Motor stops Dead
The motor is fine, you need and new walking belt and possibly a deck.
Oct 23, 2017 | Nordic Track Treadmill Motor 215392
Is the motor gone in my machine. power coming through
is the light coming on?
do you smell anything around the motor?
it is possible that the motor could be going out.
does it sew any when you push on the foot pedal?
Oct 11, 2012 | Brother Sewing Machines
I have a Amana ssd21sl, the evaporator coil freezes up, The fan motor above does not come on, but have 115v to it, Is fan motor bad.
You really need to measure the Ohms resistance for the motor.
OL means the motor is dead
0.000 means the motor is short circuited and is dead
160 to 300 ohms the motor is good
Mar 24, 2011 | Amana Refrigerators
How to tell what 1360 motor is, stroker, 89?
stock bore on a 1340 evo is 3.498" the stroke is 4.250" remove cyclinder head,with piston at TDC (top dead center) turn motor over till piston is at BTC(bottom dead center) and measure that is your stroke
Mar 11, 2010 | Harley Davidson XLH Sportster 883...
2001 Avalon was dead (battery). Won't start or jump
If the battery is fully charged there is but one thing tjst gives you those symtoms. You simply have a bad connection at the negativbattery cable. It won't hurt to ck the positive cable also. This os a common thing when a battery is connected and idle..Always disconnect the bat neg if the the vwhicle won't be used for more than two days. If possible, don't charge your dead battery with the alternator of the vehicle. It could very possibly cause charging problems. The clickinf is from insufficient voltage and jump stating with te dead battery still in place doesnt work because the goog and bad batteries are try to balance again, causing low voltage/amps to the starter. Good Luck. Sorry about the lesson, habit.
Sep 22, 2009 | 2001 Toyota Avalon
Hitachi EC12 AC is "dead"
you should take the cover off where the pressure switch is (the on off switch) and see if any wires fell off the connectors. the white wire should go straight throu to the motor, then the black wire will go to the switch than the pressure switch then to the motor. if you are careful enough you could temperarly straight wire the black wire from the cord to the motor wire.
Apr 12, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
