Question about Lowrance LMS-332C GPS Receiver
Hello- My 332c will not show speed. It worked before.The spinner wheel is not damaged.Speed just flashes 0.00 mph Thanks, Jeff
    Scholar:
  • 30 Answers
Try setting up the speed in the overlay data menu again:
1. Press MENU, arrow down to OVERLAY DATA and press ENT
2. Highlight the option for speed (WATER SPEED or GROUND SPEED) and press ENT
3. Highlight the REMOVE button and press ENT
4. Highlight (PRESS ENT TO ADD) and press ENT
5. Arrow down to SONAR DATA and press ENT
6. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box
7. Press EXIT twice
If the speed is still flashing, the data is still invalid. Try resetting the unit completely:
1. Turn unit off
2. Press and hold the PAGES and POWER key until the "DO NOT RELY..." alarm appears
3. Set up the overlay data for speed again: 1. Press MENU, arrow down to OVERLAY DATA and press ENT; 2. Highlight (PRESS ENT TO ADD) and press ENT; 3. Arrow down to SONAR DATA and press ENT; 4. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box; 5. Press EXIT twice
If the speed is still flashing, good chance the speed sensor is bad even though the wheel still spins. Install the latest LMS-332 updates from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/ and set up the overlay data again.
If it turns out that the speed sensor is bad, just use speed from the GPS. This can be set up from the overlay data menu as GROUND SPEED.
(note: the overlay data must be set up for each page individually. So if you set up speed to be displayed on the map screen, it will not also be set up on the sonar page)
Posted on Jul 14, 2009
Go to meniu find not water speed but ground speed
Posted on Sep 01, 2009
Co221 and co225 both left and right side. 2000 s10
DTC C0225 LF Wheel Speed Sensor Circuit Open or Shorted (325 ABS)
As the wheel spins, the wheel speed sensor produces an AC signal. The electronic brake control module (EBCM) uses the frequency of the AC signal to calculate the wheel speed.
Diagnostic Aids
Thoroughly inspect any connection or circuitry that is suspected of causing an intermittent malfunction. Inspect for the following conditions:
• Backed out terminals
• Improper mating
• Broken locks
• Corrosion
• Improperly formed or damaged terminals
• Poor terminal-to-wiring connections
• Physically damaged wiring
• Wiring broken inside the insulation
If the customer's concern is that the ABS indicator lamp is on only during humid conditions such as rain, snow, or vehicle wash thoroughly inspect all wheel speed sensor circuits for signs of water intrusion. Use the following procedure:
Spray the suspected area with a 5% salt water solution (two teaspoons of salt to 12 oz. of water).
Drive the vehicle above 24 km/h (15 mph) for at least 30 seconds.
If the DTC returns, replace the suspected harness.
When inspecting a wheel speed sensor, inspect the sensor terminals and the harness connector for corrosion. If evidence of corrosion exists, then replace the wheel speed sensor. Refer to Wheel Speed Sensor Replacement .
May 23, 2018 | Cars & Trucks
Intermittent abs light
What make , model an year vehicle ? Is the wheel speed sensor integral to wheel bearing hub or separate ? Could be a corroded tone ring on half shaft . ABS activates on every stop damaged tone ring
Sep 13, 2016 | Cars & Trucks
Truck starts to shake at 40 mph gets to 45 mph then the shaking stops after 45 mph
Many possibilities. I would start with wheels, and take it to a well equipped tire dealer. Have them check that the wheels and rims are clean, properly torqued. Spin the wheels up to speed and check for dynamic wheel balance. Check for broken radial belts. Check for recalls on your tires. Check for driveshaft and universal joint damage/ balance.
Mar 26, 2015 | 2003 Ford F150 Regular Cab
Cruise control stop working light dont show on dash can a fuse be out if so where is it located
There are three fuse's in the smart junction box , do you know where it is ? It's under the dash panel left side ! The fuse's are F2.27- 10amp , F2.32 - 10amp , F2.17 - 15 amp . They power the speed control servo ! Maybe the control switch's on the steering wheel don't work.
A little back ground on the system ! Speed Control The vehicle speed control system consists of the following components:
  • Brake pedal position (BPP) switch
  • Speed control actuator cable
  • Speed control switches
  • Speed control deactivator switch
  • Speed control indicator
  • Smart junction box (SJB)
  • Principles of Operation
    The speed control system is designed to maintain vehicle a set speed above 48 km/h (30 mph). After the speed control ON switch is pressed, pressing the speed control switch SET/ACCEL will activate the speed control actuator. To increase a set speed, either press and hold for continuous acceleration, or momentarily tap the speed control switch SET/ACCEL for 1.6 km/h (1 mph) acceleration increments. To decrease a set speed, press and hold the speed control switch COAST until the target speed is reached, or momentarily tap the speed control switch COAST for 1.6 km/h (1 mph) deceleration increments. When the speed control system has been disabled by tapping the brake pedal, the speed control switch RESUME can be pressed and the vehicle will return to the original set speed if the vehicle is traveling over 48 km/h (30 mph) and the speed control switch OFF has not been pressed.
    NOTE: The deactivator switch is provided as an additional safety feature. Normally, when the brake pedal is pressed, an electrical signal from the brake lamp circuit to the speed control actuator will deactivate the system. Under increased brake pedal effort, the deactivator switch will open and remove power to the speed control actuator, releasing the throttle independently of the speed control actuator.
    NOTE: The clockspring provides the electrical interface between the steering column wiring and the speed control switches in the steering wheel.
    The inputs to the speed control actuator are:
    • Vehicle speed signal
    • Deactivator switch
    The outputs of the speed control actuator are:
    • Speed control indicator lamp
    • Speed control actuator cable controlling the throttle position
    • Inspection and Verification
      NOTE: If any concerns are noted with the speedometer, stoplamps, or horn, address those concerns by referring to the appropriate sections before continuing speed control diagnosis.
      1. Verify the customer concern by operating the speed control system.
      1. NOTE: Any aftermarket modifications, including but not limited to those listed below, may cause the speed control to not operate correctly:
        • Any wiring or lamp modifications affecting the brake lamp operation
        • LED brake lamps
        • Non-factory installed trailer wiring
        • Radios (speed sensitive, auto mute)
        • Remote starters and alarms
        • Lighting and electrical accessory modifications
        Visually inspect for obvious signs of mechanical or electrical damage:
        • Visually inspect the speed control actuator and accelerator controls.
        • Visually inspect the speed control cable without removing it and ensure smooth cable operation. Inspect the speed control cable connection to the throttle body.
        • Visually inspect the accelerator cable without removing it and ensure smooth cable operation. Inspect the accelerator cable connection to the throttle body. Also check for cable interference with the carpet, bulkhead grommet, insulation and instrument panel wiring.
      1. Visually inspect for obvious signs of mechanical and electrical damage.
      2. Visual Inspection Chart Mechanical Electrical
        • Throttle linkage
        • Battery junction box (BJB) fuse(s):
          • 4 (40A)
          • 12 (60A)
        • Smart junction box (SJB) fuses:
          • 14 (15A)
          • 57 (10A)
        • Wiring harness
        • Loose or corroded connections
        • Powertrain control module (PCM)
        • Bulb
Mar 14, 2015 | 2007 Ford Taurus
When breaking the abs goes off when you get down to about 5miles
rust build up between your wheel speed sensor and knuckle in 1 or both of your front hubs likely causing vehicle to think lockup has occured at low speeds. replace your faulty wheel speed sensor/s. monitor with scan tool that shows individual wheel speed of front sensors and replace the 1 that does not read the same as the other 2
Nov 17, 2009 | 2000 GMC New Sierra 1500
2001 pontiac grand prix with speedometer intermittently inoperative.
Hello! It sounds as if you have a wheel speed sensor that is failing. The wheel speed sensor calculates the wheel/tire revolutions and sends this information to the speedometer, which then displays that information as MPH/KPH. On 97-06 Grand Prix's this and the ABS sensor are the same module, and in order to replace, you must replace the entire hub assembly. Here is a view of the hub assembly from the back side of the hub/wheel assembly. You may want to inspect the sensor wires for any fraying, loose connections, etc.
Hope this helps. Thanks for using FixYa!
Oct 01, 2009 | 2001 Pontiac Grand Prix
Vibration on Honda CR-V 2006 at speed 40-50 mph
This is your one of your axels.. they are damaged inside.. Get them removed asap it can cause major damage if it brakes loose..each axle costs about $90-100
Sep 28, 2009 | Honda CR-V Cars & Trucks
Flashes "D4" and speedometer shows 0 MPH while driving
this sounds like a Transmission Speed Sensor. ive done about 20 of them , common on hondas
Sep 30, 2008 | 1994 Acura Legend
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
Lowrance LMS-332C GPS Receiver Logo
432 people viewed this question
Top Lowrance GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
