Question about Jeep Optics
How do I put on the neck strap? - Jeep Optics
  • 112 Answers
Most jeep binoculars are not worth the price of a neck strap
Posted on Aug 06, 2009
No neck strap....what's the easiest (and safest) way to install one yourself? hdc-hs900
Amazon USA have this "Deluxe Neoprene Black Wide Neck Strap For The Panasonic HDC-TM900, SD800, SD900, HS900 Camcorder by DBROTH" but I do not know how it fits.
Sep 12, 2011 | Panasonic HDC-HS900 Camcorder
How do I replace the Fuel Pump?
The fuel pump is located in your fuel tank...you have to drop your fuel tank to replace it...before you do so you will have to sifion [sp] most of the gas out as gas is heavy...when you get out all you can leave the gas cap off and remove the bolts holding the filler neck in place...Then jack up vehicle and place on jack stands....Remove battery ground cable,go under and remove sheild covering fuel tank,while there remove the ground strap attached to the filler neck...Once the cover is off this will expose the 2 tank holding straps.....at this point you will need a jack or holding and lowering devise to support the gas tank..... make sure it is supported well before you loosen the strap bolts!!!! disconnect the EVap hose from canister it runs to tank then remove the strap bolts ...move them aside and lower the tank enough to expose the top where the fuel lines are disconnect them and the electrical connector,ground ...then lower gas tank slowly checking nothing is still hooked to it ...After the tank is down remove it from under vehicle and use a BRASS punch or piece of wood not a regular metal punch to remove the pump retaining ring ...once ring is removed CAREFULLY remove the pump from the tank.....replace pump and new strainer... Then Carefully put the pump back in the tank...if needed replace the ring seal before you place the pump back in...tighten up the retaining ring ....take back to car and put on supporting devise and lift just high enough to reattach all your connectors...then jack up the rest off the way attach holdings straps ,cover,ground ******** filler neck,filler neck bolts,battery cable install gas cap and start hopfully
Nov 09, 2010 | 2001 Chevrolet Impala
How do I attach a jump ring to the sandisk so I can attach a strap? Where can I get a jump ring small enough and where do I get a strap?
Hi, if you go into any phone shop and buy one of their straps they come with a cord that you loop through the hole and back on itself and this cant then come undone by mistake, its like a nylon thread that you feed through the hole and then put the end through the whole and pull tight you then just clip the strap onto the clip on the loop part, this is very secure and strong as its made to hold the weight of a mobile phone worn around the neck, how ever if you dont want the long strap you can just use the small loop part to attatch it to a key ring or similar.
I know you may be a bit confused but if you go into a phone shop and take the usb drive with you you will see exactly what i mean, these straps also cost near nothing so you cant really lose.
go into any small phone shop or market stall that sells phone accessories and you will see the neck straps im going on about you have the long neck strap part and this attatches to a small nylon loop that you can feed through the tiny hole on the flash drive
hope fully you understand what im saying.
let me know if you have any problems
Jul 06, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I need to put the shlder/lap strap back in
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
Jan 24, 2010 | Eddie Bauer 3-In-1 with Latch
Ataching neck strap
Put the unit on a table with the eyepiece up. Put the small loop of the wrist strap through the place provided under the eyepiece. (small slot with a pin) Put the rest of the strap through the small loop and pull tight. That's it........
mtg
Jan 28, 2009 | Bushnell SCOUT 1000 Rangefinder
Attaching Neck Strap to SanDisk Cruzer Mini 1.0 GB
There should be two holes to thread the neck strap through. I believe you have to loop them in a certain way so it stays there.
Jan 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Camera was dropped with lense out
These cameras are much too fragile to survive a drop, using the wrist strap is an absolute necessity.
Aug 18, 2008 | Cameras
Loose Latch - does not lock
I had the same problem - my fix is simple, cheap and works great - obtain some of those double sided hook and loop (Velcro) straps used to tie cables in a neat bundle - the 3/8" - 1/2" wide version works best, these are approx 4" long and usually black in color - costs approx $2 for a package of 10 straps.
Cut off a piece from one of the straps, approx 1" long and glue this to on side of the neck of the charging base. Glue the reverse side of the remainder of the Velcro strap to the other side of the neck, position it with enough length to go over the top of the push in plug (when closed), at the top of the neck, and cover the full length of the first piece of Velcro glued to the other side of the neck + remember allow some additional length so you can easily grab the end of the long piece to release the Velcro grip and let the plug raise clear of the razor.
When the glue is dry, pull the long end over the top and position it to hold the neck plug completely down, and be retained by the first piece of Velcro on the neck - trim the long piece to length, remember you need a little extra length, to make releasing the Velco grip easier. I just pull on the long end of the Velcro, this closes the plug into the razor and simply push the Velcro together to start the cleaning process - simple and cheap.
Mine has been working for years.
Sep 06, 2007 | Braun Syncro 7526 Electric Shaver
Optics Logo
176 people viewed this question
Top Jeep Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
Are you a Jeep Optic Expert? Answer questions, earn points and help others
