Question about E-Machines eMachines Monitor E15T4
Emachines monitor my son was pushing the buttons on the front of the monitor and now the colors are all wrong i tried adjustng them but its not fixing the problem what are they sup. be set on and also whats the color and brightness sup. be set on?do you know
  • 86 Answers
Most monitors have a reset back to default display settings. Just choose this option and you should be fine. Just bring up your monitor menu and see if you have a settings menu. If you do, I bet it is there.
Posted on Nov 16, 2007
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
My Emachine monitor had a gray box w/volume control that keeps popping up in the middle of my screen. I have tried numerous things to make it disapear and it seems when I think it's gone for good it pops...
As a monitor tech, I have to say. You two dopes are completley useless. My son, LB who suffers from severe downsyndrome among other ailments. Quickly figured out that if he stuffed the eraser he was eating between the base and the menu button, the problem would go away.
Congrats on being outsmarted by my disabled son who eats pennies and erasers.
You should be proud. Next time, don't be so, You know....havanagilaish.
Aug 30, 2010 | E-Machines eMachines Monitor E15T4
My computer monitor has a green tint to it, can't seem to fix the color help
First, check your video cable. It should be securely connected to the computer (and monitor if not built in). If you can, try a new cable. Try the monitor on a different computer and the computer with a monitor that works on another computer. (This tests if the monitor or the video output is the issue.) Once you figure out where the failure is, you can decide whether to repair or replace the monitor, or deal with the video card.
I hope this helps.
(we had a monitor that went pink due to a loose vga cable. once we looked at the cable instead of the computer or monitor adjust buttons, the fix was easy.)
Feb 28, 2010 | eMachines T5274 Desktop PC
Emachines g520 laptop, the monitor this morning is now blank and when the laptop fires up there is no sound or action, just the hdd light. according to my son, the laptop started to install updates,...
  • Push and hold the power button for 10 secs.
  • Then turn on and keep tap F8 key.
  • there you select last know good configuration.
  • It will take you to destop.
Please rate me!! Thanks, SF
Jan 28, 2010 | E-Machines eMachines Monitor E15T4
Emachine T3504 monitor controls locked out
The problem is not one easy... The IC with controls system is down... sorry but u must go to an expert to fix the bug! Rate me if this help's you Thanks!
Sep 14, 2009 | E-Machines eMachines Monitor E15T4
Reset 19 lx
Try pressing the "Menu" button and look for "Settings", find "Factory Settings" and select.
Sep 13, 2009 | Computers & Internet
We have a emachine 17 widescreen monitor E17T6WTFT. it is plugged in but it will not turn on. Have only had it for 6days
We could go through many troubleshooting procedures but if it's only 6 days old take it back and get a new one. There's no reason you should try to fix their problem.
The only obvious thing to check is that the cables are seated, secure and functional. Also, when you press the power button, do you get any light around the power button at all? If so, what color is it?
Jan 11, 2009 | E-Machines eMachines Monitor E15T4
Color on monitor
First, have you degaussed the unit to stop any magnetic interference?
Do you use software to change monitor settings or do you use the on screen display menu on the monitor?
Most lcd's have a button for menu on the lcd. This can be used to adjust color, contrast, brightness, degauss, as well as screen position and size.
Mar 06, 2008 | E-Machines eMachines Monitor E15T4
Emachine monitor E17T4 does not respond when the front switch is depressed
Have you found a solution yet? I just posted the same problem with my E15T4.
Dec 18, 2007 | E-Machines eMachines Monitor E15T4
E-Machines eMachines Monitor E15T4 Logo
243 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
