Question about Palm Tungsten T3 Handheld
Synchronizing Tungsten T3 with desktop or laptop
I recently re-installed my T3 program after some revisions to my desktop running XP Professional. When I push the synch button on the cradle, both my handheld and desktop tell me that the synchronization is happening, but when I look at my Palm program on my desktop, it is empty - nothing has transferred. I installed the T3 program on my laptop and get the same result. What am I missing here?
BM, Toronto.
    An expert who has written 2 tips or uploaded 1 video tip.
  • 20 Answers
Re: Synchronizing Tungsten T3 with desktop or laptop
What do you mean?
  • Did you restore your T3 from a backup on the PC?
  • Did you install programs on the T3 using the PC's "quick install"?
Is Palm Desktop showing the correct Contact/To-do/Calendar Data?
How are the conduits set up? (From Palm Desktop, select Hotsync->Custom)
Posted on Jan 18, 2008
0 characters
3 Points
Replacement new Battery In PDA not functioning
I will be writing off the PDA as it is now over three years old and updating to more recent technology. I have not yet made my repalcement choice.
Jan 28, 2010 | Palm Tungsten T3 Handheld
My son gift me a Palm T 3,but He can't find the CD to install it
You will need the Palm Desktop...this can be obtained at:,kb=PalmSupportKB,t=home,varset=fn:tungsten,varset=mn:t3,varset=cn:unlocked,d=7EAE00873809449DAF6801DEDE42E0E6,question=ref(q_activetab):str(home),varset=strDeviceScope:tungstent3
Hope this helps...
Jan 22, 2009 | Palm Tungsten T3 Handheld
Data Lost - Palm T 3
  1. BACK UP YOUR PALM DATA! It is normally in C:\Program Files\PalmOne\XXXXXX, where XXXXXX is the first six of your Palm's User ID. If it is not there, the location can be found in Palm Desktop (Tools-> Options).
  2. Is the correct Data still present in Palm Desktop? If Yes, you're in great shape, it should sync back to the Palm after a hard-reset.
  3. If not, close Palm Desktop and look in the data directory. Some subdirectories (address, datebook, etc.) should have BAK files. If the BAK files are bigger than the DAT files, delete the DAT files and rename the BAK files to DAT. Restart Palm Desktop. Is the data there now?
If not, I am afraid you've had a learning experience. My Palm is synced to two different machines. One is running RAID-1 (mirrored drives), and both are backed up to tape weekly. Me? Paranoid? Naah...
Most people have to find out about backups the hard way.
Dec 02, 2007 | Palm Tungsten T3 Handheld
Lost Data
Sounds like you've wiped all your data. It's a good discipline to keep a regular backup of all your Palm files on the PC so that if this happens you can restore the last backup and re-synchronise. I have had several Palm devices, and all of them have corrupted files at some point.
Palm tungsten not switching on
Make sure that it has a full charge. I have been having problems with it not turning on as well, but it sounds like a different problem. I have bought a new battery from ebay and installed it. It is holding a charge great, but still isn't turning on all the time. I think the prob is with the datebook or something else. Good Luck!!!
Mar 01, 2007 | Palm Tungsten T3 Handheld
Tungsten E- Synch appears to work but nothing actually happens
1. Go to red/blue arrows in lower right corner
2. Right click and select custom
3. Make sure pc know WHAT you wish to transfer and direction
You might not be letting it overwrite anything
Sep 12, 2005 | Palm Tungsten E Handheld
T3 sync with Outlook works except for Tasks
A hard reset of my T3 and sync with 'Desktop overwrite HH' on all Outlook conduits seemed to have resolved the problem.
Sep 11, 2005 | Palm Tungsten T3 Handheld
'Reset' each time after hotsynching
Do you still have administrative access to your laptop? IIRC there are some problems with using PD with a non-admin account.
I would recommend that you back up the "good" backup data on the Laptop. In PD, Choose Tools/Options, the "Data Directory" entry shows where the data is stored (in a subdirectory that looks like the first six characters of the Palm's User ID)
Errors sync with Outlook 2003 and Tungsten T3
I did search through the forums before posting and the only "solution" I found was to buy Chapura PocketMirror for $30 which I refuse to do. I should be able to sync this palm with Office without having to spend even more money.
1 palm + 2 computers = successful hotsync?
Yes and.. no.
It is possible to have one Palm synchronized to 2 PCs (I do this with my T3), just make sure that you don't end up with any "overlapping changes" - items that change on both machines.
However, since Syncing takes a full backup of the Palm, having two completely different sets of data on two different machines is complicated at best. If you are are not careful you could lose all your info by accident. One way to get around this would be to put everything on on the T3 and use categories to separate work and personal items - which is what I do.
However, if you are dead-set on keeping all of your work stuff in one place and all your personal stuff in another, I would recommend that you get a second T3.
Sep 07, 2005 | Palm Tungsten T3 Handheld
Palm Tungsten T3 Handheld Logo
168 people viewed this question
Top Palm PDAs Experts
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
