Tv has no sound.
Has no sound. It did when I first turned it on today, but now it does not. I have checked the mute button, and when i punch the audio program, I am setting it to stereo?
    Genius:
  • 1,074 Answers
Have a tecch check your tv there is an ic in the sound circuit that needs to be replaced good luck
Posted on Jul 12, 2009
How do I fix a sound problem on my television?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jun 23, 2016 | Televison & Video
No volume today on my tv
Apr 02, 2016 | Televison & Video
LG TV 55LD520-US having audio problems. No audio, when shut off speakers and turn on audio comes back on. This is continuous on this LG TV.
Sounds like speaker fault. Contact any service technician. Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Feb 18, 2015 | LG Televison & Video
We lost sound on our Sansui TVD2798 even though the speakers work. Mute button has no effect. Using the remote, we can't find any option for sound off or on.
There usually is an option for turning off the internal speakers as part of the TV setup routine...BUT you may have had a failure of the internal audio in your TV. Your Zenith remote might have a MUTE button which turns off TV sound and displays a mute message or the MUTE buttton might have been pressed accidentally and has become stuck
Jan 08, 2013 | Sansui Televison & Video
The mute wont go off
Check two things: first does the set have sound with just a DVD etc connected to one of the rear audio/video inputs? Second is check in menu that speakers are not turned OFF.
Oct 31, 2012 | Vizio Televison & Video
I have a Bose Wave II radio. Never a problem until today. No sound from radio, CD, aux. Display works fine. Remote works. Have tried unplugging and plugging back in. Tried turning volume up, muting and...
in your boss amplifire system hardware problem in u try to mute and volume button please check aux port also if found no output sound then go boss service station there are some hardware problem
May 16, 2012 | Bose Audio Players & Recorders
Sound not working, Was working earlier today and after shutting off the tv, when we turned it back on, sound wasen't working
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Apr 03, 2012 | Vizio 42 in. LCD TV
Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
When I turned on my Toshiba tv today, it has no
Sounds like the speakers have died, it's muted at the source (cable box / satellite box if you have one) or that the cable for audio is loose. Check those three things starting with the last one and you will be able to pin point it.
Aug 11, 2009 | Televison & Video
No sound
check your remote to see if it's on mute...or mute is enabled...check your connections from the tv to the cable box...if your using surround sound...check those connections as well...if you have a dvd player..hook it up to the tv and see if you get audio...let me know if this helps...if not i will give you more things to check
Feb 07, 2008 | Philips 60P8341 60" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
