Question about Poulan PP4218AV 18" Chain Saw
No oil for the chain
How do i clean oil holes?
no oil is getting to the chain.
poulan chainsaw
2150 woodsmans,
    Brigadier General:
  • 4,088 Answers
With the bar and chain off, start the engine. Does oil come out of the side port on the engine? If so, clean all of the holes at the drive end of the bar including the small holes that lead into the chain slot plus clean the chain slot itself. Compressed air works very well for this purpose. If oil doesn't come out of the port, then (Is there oil in the tank?) there is a problem with the filter (in the tank) being plugged or the lines to and from the pump are damaged or kinked as well as the pump being in trouble. Some pumps have very fragile plastic drive gears.
Posted on Sep 13, 2009
    Problem Solver:
  • 12 Answers
You can take the bar off and use a wire clothes hanger to clean out the holes behind the cover
Posted on Jul 12, 2009
How to adjust oil to chain on poulan 18" 42cc chain saw
Poulan chainsaws are at the cheap end of the spectrum when it comes to good chain saws. I had the same chainsaw and there is no oil adjustment. Basically, the Poulan oil feeders just drool onto the chain....whether it is running or not.
Nov 15, 2017 | Poulan Garden
How much compression should the saw have?
What Causes Too Much Compression on Poulan Chain ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Many makes of gasoline-powered yard tools, including Poulan chain saws, use two-cycle, or two-stroke, combustion engines. ... Pull the rope out and oil it to see if that helps the problem. ... How Much Compression Should a Stihl 066 Have? ... Pull Starter on a Poulan Chain Saw · Oil Pump Removal on a Poulan Chain Saw ...
The Timber Trades Journal and Saw-mill Advertiser
Nov 26, 2015 | GCSP Husqvarna 340 345 346 350 353...
What type of oil is used for my 2055 2.O CI woodsman chain saw?
This engine is certified to operate on unleaded gasoline.Before operation,gasoline must be mixed with a good quality synthetic
2-cycle air-cooled engine oil designed to be mixed at a ratio of 40:1.Poulan/Weed Eater brand synthetic oil is recommended.Mix
gasoline and oil at a ratio of40:1.A 40:1ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline.
As far as bar and chain oil:
Genuine Poulan R bar and chain oil is recommended to protect your unit against excessive wear from heat and friction.Poulan R oil resists high temperature thinning.If Poulan R is not available,use a
good grade SAE30 oil. Never use waste oil for bar and chain lubrication.
Oct 20, 2014 | Garden
Poulan woodsman 2150 starts & runs for a few
This is fuel starvation, start by replacing the fuel filter inside the fuel tank, use a piece of bent wire to hook the fuel line and filter out of the tank, check the condition of the fuel hoses up to the carb, any signs of leakage and you will have to change the hose. See if this works before we go into the carb to locate the blockage.
Jun 09, 2013 | Garden
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Poulan 2150, chain oiler not working. Chain is getting very hot.
Try to pour some gasoline only in the oiled tank and look if the gas comes out, if not the tank is clogged .
Oct 12, 2010 | Poulan 18" Chain Saw Replbar (small Saws)
I have a Poulan 2150 2.1 chainsaw. I have no manuals. All of the fuel lines are dry-rotted and need to be replaced. How can I do this myself?
An IPL containing fuel system parts with very little detail can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
“2150 Gas Saw Type #” (the dash number from your serial number). May also be Predator or Woodsman.
The fuel system parts can be found on the "Engine Assembly" and "Handle & External Assembly" illustrations.
Take good notes and a some digital photos with as much undisturbed detail of hoses and routing as possible.
Try your local chainsaw seller/mechanic for fuel hose. Take a short length sample, there may be different size hoses. All need be fuel resistant.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Oct 30, 2009 | Poulan Garden
Poulan PP4218AV 18" Chain Saw Logo
411 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Poulan Garden Expert? Answer questions, earn points and help others
