Question about Kicker SX1250.1 Car Audio Amplifier
Service light on
I have a kicker sx 1250.1 amp and it says service amp what do i need to do
    Scholar:
  • 108 Answers
You may have blown your amp. It just depends on how hard you run it, and how hot it gets. Check the onboard fuses and make sure they are still good. You can try pulling the heat sink off (the top cover) and look to see if anything is black or burned, even if there is a lot of dust inside the unit. If you got it from a store like best buy you can try taking it there and have them look it over. Places like that tend to have a service tech on hand.
Posted on Jul 12, 2009
What oil pressure is needed in the rams on the back door which set bale pressure on a krone 1250 round pack
tough question that
http://www.mascus.co.uk/specs/round-balers_985594/krone/round-pack-1250_1024021
Krone Round Pack 1250 Baler, multicut 17 knives, , rotor feed, 15.0/55-17 tyres, bale kicker, 2.0m pick up, wide angle pto c/w cam clutch.
Jul 04, 2016 | Cars & Trucks
1976 pioneer sx 1250 receiver has no sound from receiver to speakers
for
1976 pioneer sx 1250 receiverhas no sound from receiver to speakers
check the integrity of speaker systems,
check the receiver internal components, pay close attention to the
capacitors, possibly have dried up or swollen (age)
Check for continuity to the speaker outputs.
These may take some time, but I hope you will make it.
Sep 09, 2012 | Audio Players & Recorders
Unlock code SX 1250.1 Kicker amplifier
Factory defalt code is 123, unless you changed it, then it would be the code you chose.
Dec 12, 2011 | Kicker Car Audio & Video
SX 1250.1 Kicker
What's wrong with your kicker amp? Defalt code is 123.....
Dec 12, 2011 | Kicker KX600.1 Car Audio Amplifier
I dont have the blast port wire and it wont play.where can i find the wire?
  • BLAST Port (Bass Level And Signal Transfer) Provides Remote Bass Level Control and control signal transfer between multiple SX amplifiers
  • Here is the manufacturer's accessory page to the remote: http://www.kicker.com/zxrc
    Here is one on eBay: http://cgi.ebay.com/KICKER-2010-10-ZXRC-AMP-AMPLIFIER-REMOTE-BASS-CONTROL-/360328112100?pt=LH_DefaultDomain_0&hash=item53e53aa7e4
    And here is a note from Kicker on how to make a control yourself for strapping multiple amps together: I have two or more Kicker SX or KX subwoofer amplifiers. I don' t want to use all those separate bass level controls. Is there a way to make them all work with a single Kicker control knob?
    Yes. You can visit your local Radio Shack or home improvement store and purchase an RJ-11 modular adapter. You then plug the sub level cables from the individual amplifiers into the adapter. Then run a cable from the adapter to a single Kicker remote knob. All amps will now work with a single knob.
    Dec 28, 2010 | Kicker SX400.2 Car Audio Amplifier
    My amp kx1200.1 works only 5 minutes and then getting real hot somebody have any idea
    You need to swap your main battery for a high performance kinetic... and maybe even ad a small kinetic in the back as well (fused separately) and see how that works for you. Just one oversized kinetic battery replacing your stock battery may do that trick. Remember, its best to install two batteries of the same brand and size, its ok to use the same brand and two different sizes (a kinetic 2400 and a kinetic 600 for example, but with an isolator) but its easier and simpler to just put in a kinetic 1200 or something that will replace your stock power sucking ineffecient lead acid stuff.
    Jul 26, 2010 | Kicker KX1200.1 Car Audio Amplifier
    How do i bi amp sx 1250 to get both channels of each side to work together
    you are actually not bi-amping the unit, you are bridging the amp. this really only works as long as all channels produce equal power. next the bad news is that typically home stereo amps are not wired internally to bridge channels.
    bi-amping a speaker refers to connecting on channel to the highs and on channel to the lows. the receiver would need to be be able to process the outputs via a crossover network to split the frequency range in half so the appropriate frequencies went to the correct speaker.
    Sep 21, 2009 | Sunfire Theater Grand Amplifier
    Can't find part needed.(Pioneer SX 1250 volume control part # ACV-169. Is there a replacement
    Your only recourse at this time is to check with local servicers that may have one around in their old stock. Or check Ebay for a parts machine that you can salvage one from. I believe that the volume control from an SX-850 will be the same, so you can search for one of those as well.
    Good luck.
    Dan
    May 19, 2009 | Pioneer Audio Players & Recorders
    Red light keeps flashing..
    my kicker was doing the same thing, and come to find out the power was loose,
    1.check power connection,
    2. check ground
    3. check remote wire.
    4. check that your amp isn't mounted on -metal-
    5. check your fuses onboard the amp,
    6.check you speaker wire
    7.check your rca jacks
    8. check that your gains aren't too high for the wattage
    May 12, 2009 | Power Acoustik PS2-1250 Car Audio...
    Best wiring and best sub boxes for my solo x 12"
    I did not realise yall used these boomers over there. search the internet I bet you can find every thing yoy want threre. just searrch car stereo
    Mar 04, 2008 | Car Audio & Video
    Kicker SX1250.1 Car Audio Amplifier Logo
    366 people viewed this question
    Top Kicker Car Audio & Video Experts
    Morne Olivier
    Marvin
    Marvin
    Mike Duncan
    Mike Duncan
    Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
