Question about Garden
Walk behind craftsman lawn mower. starts but shuts off after 15 minutes then will restart after it sits for 10 or 20 minutes
My craftsman 917378490 left front wheel has stopped pulling.
Right front seems ok. Axle is turning on left front from gearbos.
Posted on Apr 13, 2010
Not sure what model but it sounds like it runs hot? make sure the fuel/oil mixture is correct, exhaust is not clogged, sparkplug is in good condition. hope this helps.
Posted on Jul 12, 2009
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
I have a craftsman walk behind lawnmower and my pull string will not start the motor and it doesn't lock
The small metal peice is the engagment pawl, it sits into the plastic pulley, if it has come out the pulley will probably be damaged as well, you will need to remove the pulley securing screw and big washer, you should now see the slot in the pulley where the pawl sits.
May 12, 2012 | Yard Machines 158cc Push Lawn Mower #11a...
Mower starts and immediately shuts off and wont start again if i let it sit for five minutes it does the same thing checked oil and air filter carb is clean attempting to find correct socket to remove plug
Pull the fuel line from the carb & see if it is running steady, If so the next check is the carb bowl to see if maybe the float needle is partly plugged, and then it could be the valve lash clearance which will require more mechanical knowledge.
Jul 14, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
After about 15 to 30 minutes, engine starts pinging (for a few seconds) then dies
Not familiar with tecumseh lawn boy. Lawn boys I worked on were 2 stroke, if this is the case the crank seal is sucking air after engine warms up. New seal would fix. If you can't do it you're self may not be economically worth it.
Sep 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
22 In Craftsman Self propelled.Starts easy, runs good for about 15-20 mins. Starts missing and dies. Will start again in about 30 mins New spark plug/ air filter
Oh my, that is so annoying. There is probably dirt in the carb. or the gas tank. What I think happens is, the dirt gets sucked up into the fuel line and clogs the carb, then when the mower sits for a while the dirt goes back into the tank for another couple minutes. I have absolutely no tolerance for this when it happens.
Aug 05, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
WHEN I MOW FOR ABOUT 15 MINUTES, ENGINE STARTS LOPEING, RUNNING ERRACTIC AND SHUTS OFF. TRY TO START AGAIN, WON'T START. SEEMS LIKE WHENS IT'S COOL WILL RUN FOR AWHILE. LAWN BOY 21'' CUT, WALK BEHIND...
on the side of your mower by the exhaust, there should be a plastic cover about 2"wide by 3" long, inside of this is your air filter take it out & clean it with a air blow gun, or tap it until clean, see if that helps.
Oct 03, 2009 | Garden
2 year old craftsman 42" deck tractor runs fine for 15 minutes then sputters and dies. Will start, run 2-3 minutes, die again. Leave sit will run for 20 minutes.
if it restarts immediately, check the vent in the gas cap for restriction. also, the solenoid on the bottom of the carburetor may be sticking or getting weak. if you have to let it sit for awhile before it retarts, the ignition module may be breaking down when it heats up. i'd bet on the gas cap or solenoid though
Sep 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Walk behind lawnmower
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Craftsman 5HP Mower does not start
try changing your primer bulb
May 31, 2009 | Craftsman Garden
Garden Logo
839 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
