Question about Tascam US-144 Sound Card
Midi stops working
Hi i've been using my new us 144 with reason 4 running on OS 10.4. If i let go of my keyboard and stop playing notes for about a minute, I am unable to play anything again through midi with my keyboard, but if i have anything sequenced out and i hit play, it all plays back. the whole interface doesn't completely stop working, just the midi if i try to play a virtual instrument. I tried using the exact same setup but instead with my old us 122, and didn't have this problem at all. is there anything i can do besides throwing my us 144 away and buying something else?
  • Anonymous Jan 06, 2008
    same with garageband. lets you record midi once then won't work again unless you restart garageband. osx 10.49, latest tascam drivers and firmware.
  • Anonymous Feb 15, 2009
    seeing the same thing. anyone find an answer yet?
SOURCE: tascam US-122 USB Audio/MIDI interfaces driver
the software is made by Steinberg and uses ASIO drivers that are at the address i gave you;9,15,69,19.html
works fine on my XP machines
Posted on Dec 14, 2007
SOURCE: Problem with the Tascam US-122 audio/midi interface
lol ..
i had the same problem..but its not that big of a deal
just switch it to "mono" on your interface
that should do it!!
Posted on Jan 22, 2008
  • 979 Answers
SOURCE: Midi notes
Be sure to turn of the SYSTEM EXCLUSIVE command on your keyboard...accordianman
Posted on Apr 05, 2008
  • 659 Answers
SOURCE: us-122 lost cd;9,15,69,19.html
there is all the info you need there good luck its a nice unit
Posted on Nov 28, 2008
  • 1738 Answers
SOURCE: where can I find compatable windows 7 drivers for
I couldn't find any drivers available for Windows 7. However, you may be able to run it in 'Compatibility Mode'
See: How to run in compatibility mode Windows 7
US-122 Windows Drivers: v. 3.40 Release Notes (download)
- v. 3.40 Windows Vista and XP Driver (download)
- v. 3.30 32 Bit Windows XP driver (download)
- v. 3.30 64 Bit Windows XP driver (download)
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Posted on Feb 03, 2010
MIDI Basics
MIDI is the language used by electronic instruments to tell each other what to play. When you press a key on a musical keyboard this keyboard will send a MIDI message to a computer or a musical instrument connected. The message says something like: start playing this note at this volume. When you stop pressing the key a new message is sent which says: stop playing this note.
MIDI messages can be transmitted using MIDI cables or USB. Old instruments had MIDI ports (round with five connectors inside) so a computer had to have a MIDI interface. Nowadays it's almost all done with usb.
The important thing to remember is that a MIDI message (and a MIDI cable) are just an instruction to play, they don't contain sound. The sound you hear when you press a key comes from the computer or the instrument connected to the keyboard, not from the plastic key you have pressed.
There is a lot more to say, but I would suggest you check wikipedia first and then come back with more specific questions.
Nov 09, 2012 | Yamaha PSR-E433 61-key Keyboard, with...
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
When I connect my midi cables to my PC and use Fruity Loops or Mixcraft and I play notes on the Roland Juno D keyboard, some of the notes stick and dont stop playing once released and others are played...
The name for the notes that don't stop playing is "Dreaded MIDI Drone". It is caused by multiple note on commands and lost "mating" note off commands.
Also read "c." on page 80 regarding buffer length and "choppy" sounds.
Feb 05, 2011 | Roland Juno-D
My keyboard notes, when reading midi tracks, sustain; get stuck
Try updating your OS to 10.12.3, the latest version. Make a total backup first!
Mar 13, 2017 | M-Audio Firewire 410 (mfire410)
Reasons won't record midi data
Hi Danadepatter,
You have to check were the problems is, with exclude way.
1. you first find out if your "master keyboard" really works: Try to run another program where you can run the the keyboard(you can use a trial and the uninstall it after)
2. if that works then it is another place not the keyboard, then it can bee the program / sound card / configuration . you can find the reason manual here :
Check if the configuration to the midi keyboard is ok.
FOR THE SOUND CARD: be sure that you do not have anything else that can interrupt the sound card. Shut down other recorders and other software that use the sound card and bee sure that you use the same sound card configuration (normally it is realtec the default)
If nothing happens please go to the support here for Reason software :
Hope that helps
Have a nice weekend
Please rate my answer
Sep 25, 2009 | Propellerhead Reason 3.0 (991010004) for...
MIDI Keyboard note delay problem, not latency problem PLEASE HELP
You are suffering from midi latency. There is a good article about this at There is also some good advice there.
May 05, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Sound module & mic (connected to a Tascam US-224) not working
I may be able to help.  I am a longtime Mac and Tascam control surface user.  I am currently running a MacBook Core 2 Duo 2.0GHz running OS 10.5.6 with a Tascam FW-1884 audio interface/mixer/control surface connected.
Setup is fairly easy in the Mac OS.  Here are the steps I'd follow:
NOTE: Before beginning the following process make sure that ALL of your MIDI gear is connected.
- Tascam connected to USB port of computer
- MIDI Keyboard "OUT" connected to Tascam "IN"
- Roland "IN" connected to Tascam "OUT"
1) Open your "Applications" folder.
2) Open the "Utilities" folder.
3) Double-click on "Audio MIDI Setup."
4) At the top of the window select "MIDI Devices"
5) In the pull-down menu on the left select "New Configuration."
6) Title your configuration and press "OK"
7) If your gear has been detected automatically their names and icons should appear in the main window.  If so, skip down to step 12
8) Click on the "Add Device" button
9) Double-click on the "new external device" button that has now been created.
10) Select your device's manufacturer and model (i.e. Roland, JV-1010).
11) Adjust any other settings appropriate to your setup.
[In the main window there should be a Tascam US-224 button.  On it there should be one pair of arrows that indicate the MIDI In and MIDI Out ports of the device.]
12) Click (and hold) on the MIDI Out arrow of the US-224 button.
13) Drag the "cord" and attach it to the MIDI In of the Roland JV-1010 button.
13) Click (and hold) on the MIDI In arrow of the US-224 button.
14) Drag the "cord" and attach it to the MIDI Out of the "keyboard" button.
This should get you setup from a Mac OS/Device routing perspective.  For the appropriate US-224 Control Panel settings refer to the User Manual.
Feb 07, 2009 | Tascam US-224 DIGITAL AUDIO WORK STATION...
Notes don't stop even after I release the key
The keyboard  is not sending a note off instruction after the key is released. Try checking midi preferences in reason.If your using a Mac check that the edirol is present by launching Audio MIDI Setup utility located in the utilities folder. You can download the latest Mac driver from Roland below: EDIROL PCR-300 32-key MIDI Keyboard Controller :: Download
Jan 18, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
Are you hearing the sounds from your speakers on your computer only?...accordianman
Feb 03, 2008 | Tascam US-144 Sound Card
Midi notes
Sep 14, 2007 | Tascam US-122 Sound Card
Tascam US-144 Sound Card Logo
108 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
