Question about Garden
I can't get my trimmer to start, it just floods.
  • 60 Answers
Check the spark plug
Posted on Jul 12, 2009
2 Suggested Answers
evwood
  • 50 Answers
SOURCE: Trimmer is flooding.
It appears that the carb is not functioning properly. Sounds like the needle is not seating properly. It will need cleaning or repair.
Posted on Feb 09, 2009
Why does my Husqvarna 122c trimmer not start?
try this hold the throttle open all the way then choke it or primer if you have one then pull stat it . it should start up this is a trick that lawm mower tech use to start badly flooded trimmers are new trimmers that have not start it gets them to start right up so they can adjust the carburator so they will run this might help you to start the new trimmer you have
May 19, 2014 | Husqvarna Garden
I can't get it started and I"m following directions on side of machine.
Those direction are not accurate all the time, I usually prime mine 4-6 times. put mine on full choke with the trigger pressed and pull 1 time any more will usually flood it, If you have the choke that kicks off after you press the trigger, put the choke back on to half and pull the cord pressing the trigger, Then pull the cord until it starts without pressing the trigger. As before if you press and hold the trigger during the start it will flood these trimmers..This should start the trimmer. You may have to let the trimmer set for about 15 min if it was flooded.
Sep 19, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Trimmers floods its self, will not stay running
It is unusual for a trimmer to flood itself. It is common to have a lean condition diagnosed as rich.
So lets start by seeing if its lean or rich. Get unit running and apply as much throttle as possible and keep unit running then slowly close the choke. If unit starts to run better as choke is closed then it is lean. If unit dies immediately and is hard to start again it may be flooded.
4 possible reasons for flooding...
1. piece of debris in inlet needle, needle lever adjusted too high
2. adjustment screwd turned too far out
3. exhaust screen clogged
4. low compression
If unit has a stuck inlet needle it will flood while engine is off and be very difficult to start- remove fuel source and/or turn adjustment screws all the way in and pull rope until unit starts ( 4 or 5 times)
clean the carb, screws should start at 1 and 1/2 turns out on the low and 1 turn out on the high.
clean the screen.
If the unit has low compression it is not worth repairing- the cost of repair will exceed the cost of replacement.
Jan 02, 2010 | Homelite Mighty Lite Lawn Trimmer
Flooding carburator
your going have to rebuild the carb.
Jul 30, 2009 | Garden
It acts like it is flooded, starts with choke off and throttle depressed. runs until carb runs out of gas then dies
Yes, Your carburetor sounds like it needs cleaned. Or you may possibly need to purchase a carb. kit for your trimmer if the cleaning doesn't do any good. When cleaning the carb. use a Den Tek Brush, (teeth cleaning brush), to clean the small ports. Also, check the small screen in carb. Can get clogged easily.
Jim
May 28, 2009 | Garden
Starting Still FS55 Trimmer
try leaving the trimmer in direct sunlight for a while and then try starting it. placing the trimmer in direct sunlight will warm up the spark plug. if it does start then it might be that spark plug is getting to be weak and may need to be replaced.
May 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Starting issue with 323l 2 stroke trimmer
Clean the carburator, check fuel stems making sure they're not screwed in to far or bent. Buy a new choke assembly and new fuel filter.
May 10, 2009 | Husqvarna 28cc Gas Line Trimmer
Nov 16, 2008 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Garden Logo
43 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
