Go in control panel --look for appearance and personalization- open adjust screen resolution see if that makes a difference
save and set
That didn't work. Also, when I turn my monitor off and on it actually gets worse. The resolution degrades and half the screen is black and pushed to the side (if that makes sense). However, I've discovered the "input" button on my monitor somehow fixes it all? Until I turn my monitor off and on again and it goes black and skewed. Any idea what this is? The input button is fixing it but there's obviously something amiss
SOURCE: Blurred Corners
hi there, its a decousing problem, look for the connection of the decousing which is connected behined the pic tube to the board. check some electronic parts, it may be temperature resistor, termistor, transistors, capacitor, etc.ty
SOURCE: font discoloration
You may not be running native resolution for the LCD screen.
Open Display control panel and on settings tab, set Screen resolution to maximum right position.
SOURCE: I need to know the
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1280 x 960 · 1152 x 864 · 1152 x 870 · 720 x 400 · 640 x 350
Synchronization Range - Vertical56 - 75 Hz
If my solution fixed your problem, could you give me a Fixya rateing? Becouse Im trying to reach the guru rank and its up to you if I get there or not.
Thanks alot!
SOURCE: Recently the font on my monitor has become a bit fuzzy.
the refresh rate frequency should be 60hz, and monitor resolution 1024 x 768 , should work fine but if the the problem still it might be the lcd monitor getting OLD :) ,you can make sure by connecting the monitor to a different pc and notice the font.
SOURCE: How do you change the font size on the monitor
To change the font size, point your mouse to the desktop then right click. Click on Properties - Appearance (tab). The third option is FONT SIZE. You can adjust the size from there.
Hope this helps. Thank you!
