Question about Panasonic Televison & Video
How does mecha recognise "tape loaded" tape deck loads, then immediately ejects; motors & belt seem OK
  • Panasonic Master
  • 5,650 Answers
All VCR have a "mode switch" as the mechanism moves so does the switch. This tells the master 'chip' what position it is in.
If it goes wrong then (as your's sounds like it has) it will do weird things.
Even if you can get one, you will need a manual to set it up, as the mechanism and switch have to be set up in a certain way in most models to get it to work right.
Posted on Jul 13, 2009
How can I eject a cassette from deck A it has taken the cassette and is not ejecting it nor is it playing it
The loading is not completing and so the mechanism will not release the forward eject of the cassettte to work. So please check on the belt and if this is worn then the loading will not work as it will slip and so will not complete the loading back to rest mode.
Jul 22, 2011 | Technics RS-TR575 Single Dual Cassette...
VCR EJECT FAILURE
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) and try loading and unloading a tape. Try to find the motor and belt which operates the loading mechanism. When it "catches" as you say, try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the tape is why you may not have this problem during the load sequence.
Jan 28, 2008 | Goldstar GBV241 DVD Player/VCR
I have a panasonic nv-hd640 i can't eject tape, when i try to eject give me a error f06 and turn off the video thank you
You have a K-Deck model there's lots of information on the net about these so check it out.
Meanwhile F06 means that the mechanism is locking up (getting stuck) after unloading the tape. The cause of which is either something to do with the loading motor or the carriage (where the tape fits) alignment.
Just type "Panasonic K-Deck Mechansim" into Google for the information.
Jan 16, 2011 | Panasonic NV-HD670BDX VHS VCR
Vhs tape won't load completely
I assume the cassette flap lifts fully, allowing the tape to go into the deck as this is a small lever mechanism. When the tape goes so far in, it activates a switch to start the loading motor this is usually a metal or plastic pin on the deck depending on the make of VCR (as you do not mention the model of your VCR, I can only give you an overall explination of a carriage mechanism). The pins at the side can incorporate a start sequence as well & will guide the deck into position. It looks like your machine has gone out of alignment & to solve the problem you would need to remove the cassette housing & re-align the pin at the side so that it follows the correct path, this can sometimes be a tricky & awkward thing to do as you can break parts of the deck if it is not aligned correctly. My advice would be to take it to a service repair centre.
Jul 21, 2009 | Televison & Video
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
Sony slv 700 hf
The VCR is detecting something it doesn't like. Could be a foreign object inside, or the gearing out of time or ... Take the cover off and watch it as it loads and you'll probably figure out why.
Dec 29, 2007 | Televison & Video
Can't insert tape into deck
Remove the cover again and move the tape carriage all the way towards the front (the carriage is not fully in the locked position). Once that is done you should be able to load a cassette again.
Sep 27, 2007 | JVC SR-V10U S-VHS VCR
Samsung SCD-5000 miniDV tape deck problem
Hi, I have a SCD 5000 Samsung camera. The video plays and records. But the camera side does not show in the video screen. HELP me
Jul 06, 2007 | Samsung DouCam SCD-5000 Mini DV Digital...
Tape Ejects Immediately
There are normally 2 causes. One is some obstruction in the tape path. Please open the cover of the VCR and shake and see for foriegn objects. Nothing??? Then there is one more possibility - Belts are loose.. Check the Tape Loading motor belt.Is it slack? This can happen over time.Change the belt.
Feb 04, 2007 | Panasonic NV-HD680 VCR
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
