It was fine an hour ago. Purchased in Nov. 2009. Was fine earlier now showing blue tint on the bottom of the screen. White line then Blue tint.Running horizontally. Turn it off just fine, back on the section starts out red then fades to blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma &LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
SOURCE: vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ??
3. If yes ..?
4. Then change the LOGIC BOARD or PDP
SOURCE: got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
SOURCE: 42 Plasma TV has many vertical lines (stripes)
screen itself would seem to be the problem here
