Question about Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker
I have a crate mx15r amp and the component on the pc board labled ic#3, its the one thats mounted to the heat sink blew out. problem is its burned up so bad that i cant read the i.d. numbers on it to replace it. there are 5 pins on it and all are soldered to the board. any help would be oh so sweet.
  • bwcreighton Jul 13, 2009
    thanks paul could you also tell me the name of the component? whats it called?
  • 73 Answers
Hi there. This should work but check it out: pin assignment. It's a 32 watt so won't blow again. http://www.mouser.com/Search/Refine.aspx?Keyword=tda2050
Thanks
Paul
Posted on Jul 12, 2009
  • Paul McNaul
    Paul McNaul Jul 16, 2009
    Hi again.
    TDA2050 by STMicro
    32W Hi-Fi AUDIO POWER AMPLIFIER
    Thanks
    Paul
Where do I test for break in the Mx15r input cuircut if its not sending
The MX15R has a clean and overdrive channel with a common input. The reverb is between these input channels and the power amplifier. The common link between the two, is the input jack and selector switch which chooses which pre-amp section to use. I would check out this switch and jack as most likely, one of the other is open.
Jun 23, 2017 | AMP Music
Popped lights on no sound
Probably smoked the output IC(it is the chip mounted to the heat sink attached to the fan) which can be purchased from marshall directly or from one of their service centers. Also P-H216 sold at tubesandmore.com should work. No soldering required. Look at that IC(chip) to see if it looks burnt or has a crater on it which would indicate that that is indeed you bad component.
Mar 18, 2014 | Marshall MG100HDFX 100-Watt Amplifier Head
Distortion in clean channel in fender frontman 65r
If the IC is MC1436, Pin one is not connected.Pins 2, 3 and 6 are the signal carriers, 6 is out 2 and 3 are inverting and non inverting inputs. CR13 and CR 14 would be simply something on the order of a 1N60 or a !N914 depending on body size,
If it works fine with heat snk screws removed, check to see if they short something out. Also look for small cracks in the board with the screws in place and snug. It also would not hurt to reflow the solder on all component leads and headers that are in the vicinity of the heat sink. Just because they "look" okay, does not mean they may not be faulty. Reflowing eliminates a cold solder joint as a possibility- which by your description is actually the most probable issue. Followed by cracked board and inadvertant short. Esepcially if the heat sink is supposed to be electrically isolated. If it continues, try using nylon mounting hardware for the heat sink, Also when powered up tap each IC, electrolytic capacitor and transistor with a pencil eraser- those that make noise may be the source of the problem. The applied stresses of the screws might deflect the transistor just enough to make a contact intermittent internally in the device..
Oct 13, 2012 | Fender Music
While moving, the equalizer slides / controls broke off . Where can you find them and are they replaceable? Crate Telluride Accoustic amp.
Yes, the pots are replaceable. Removing them from the circuit board requires solder removal tools. DO NOT atttempt to remove these with solder wick. The new high temp solder (ROHS) will surely cause the board to be damaged. I use an Ungar powered solder removal system. The parts can be found at DigiKey.com or Mouser.com. The part value is marked as is the taper which will likely be an "A" or "B" suffix. Search for potentiometer, slide. You have to exactly match the circuit board pin layout. The distributors have links to the manufacturer's spec sheets to compare. First thing is to measure the travel, then find ones with the right mounting, then the resistance and finally the taper suffix. The parts are typically between $1.50 and $3 each.
Jun 08, 2011 | Crate CA125DG Telluride Acoustic Guitar...
I have a crate GFX 50 and the effects come in only after about 15 minutes of play.
This is a warm up issue and can probably best be found by using circuit cooler on suspected components.
Other possible problems may be a bad solder joint or cracked circuit board.
Candle the board with a bright light to look for cracks.
Bad solder joints take experience to spot, but pay particular attention where panel mounted volume controls solder to the circuit board. Looking for the little ring around the solder menicus takes a sharp eye and good lighting. Resolder any suspected bad joints.
Jul 29, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate GTX-30 Guitar Amp Schematic... The thing blew, and I need to replace two components...
Hi. use this link to check for the schematics.
crateamps.com/support/discontinued.php
or
music-electronics-forum.com/sitemap/f-60.html.
take care.
May 31, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Loud crack when turning unit on, blows main fuse no lights come on.. bottom of power supply black and signs of burn...
DO NOT REPLACE THE FUSE !!! You will do more damage.
I just repaired one of these. A small ceramic surface mounted cap very near where the +/- 85 volt connectors plug onto the board blew up.
This left a sputtered mess on the insulating material at the right rear corner of the power supply.
The net parts list of parts I had to replace:
1. Main IGBT transistors on heat sinks. You have to remove the heat sinks to get at the mounting screws. 1MBK50D or equivalent. I used DigKey part APT28GA60BD15
2. One 1N4148 surface mount diode that is for gate drive speedup. D24 and D25. (don't remember which one was shorted)
3. All four driver transistors for the gate of the IGBT's. @ each 2SA1020 (PNP) and 2SC2655 (NPN). These are tall TO92-like transistors and I believe that at least one of these I had to get from Mouser.
4. Transistor T9, suface mount BC856B (PNP)
5. Replaced all four surface mount caps, one had exploded.
C50, C51,C54,C56. Replace with 0.01mfd/200 Volt 1206 style surface mount caps Digikey 478-1511-6
6.Replaced ceramic wire wound 10 Watt stand up resistors that were blown open. Replaced with 20 ohm design change. These slowly charge the main input filter caps and when supply is stable, a relay shorts them out. If you have replaced the fuse, you LIKELY blew them out. Original value was 10 ohms on some units. This was a Mouser part. 280-PRM10-20-RC
7. The 2153 switching reg chip IC1. This chip shorts. It is made by International Rectifier and I believe the full number is something like IRF2153. I had these in stock and not sure of which source I had procured them from... It was from one or the other.
Lots of destruction and one really needs a desoldering station to work this. Removal of the blown IGBT's is especially tough. All solder must be removed from the transistor leads AND the thermistor on one of the heat sinks. Once you have verified the leads are loose, one has to rock the heat sinks to get the tabs free. The tabs are NOT soldered! Be careful when restoring to get the thermistor leads started in their holes.
Note: ALL these repair parts were procured from DigiKey.com and Mouser.com. Neither of these places had all, I had to order from both. Mouser had the ceramic resistors.
When restarting this, leave outputs disconnected until it is running again. USE a series 75 watt light bulb in the 120 volt input. ONLY work on the unit using an isolation transformer as a large portion of this is connected right to the power line.
There is a small 15 volt switching supply that comes on first that runs the relay to short out the inrush limiting resistors. With the 2153 shorted as usual, this auxilary supply can't reach voltage enough to turn on the relay. The power for this is supplied through the ceramic resistors.
May 08, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have a Crate GT 15, not getting anything to the speaker when I plug in.
Do you have electronics experience? Inspect the amp for broken or cold solder joints and any burned components. Check to see if the fuse blew and that the output IC's or transistors (not sure what Crate used in these) are not bad. Check your speaker wire as well.
Jan 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
The effects do not work on my Crate VTX 350 H, what's wrong with it?
Are you getting sufficient power to the amp?
Could be a loose connection inside the amp (such as a wire), a bad component, or a severed ground. Many possibilities here. If you know electronics, take a multimeter and start testing all the components. Look for any burn marks, check for broken solder connections, and continuity test all wires. Be careful since amps can hold a deadly voltage for a good while. Be sure to drain the capacitors before doing anything else inside it. If you do not feel comfortable doing this, you can take it to a electronics repair person. Keep in mind that Crate is one of the harder amps to fix because most of their components are surface mount.
Nov 17, 2009 | Crate Music
Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker Logo
602 people viewed this question
Top Crate Music Experts
Ben Armstrong
freddybrass
Level 1 Expert
Ron Durham
Are you a Crate Music Expert? Answer questions, earn points and help others
