Waker fills slowly making noise
Whirlpool washer fills slowly both hot & cold and makes noise like internal valves not fully open. External water lines are good and fully on. What could be problem?
  • 50 Answers
Check the screen where the hoses hoock up on the washer They mite be cloged If so use a tooth brush to clean the screens
Posted on Jul 12, 2009
I replaced water inlet valve on a lg upright washer Now it makes a high pitch sound when filling like there is air in the line . D I need to bleed a line?
Have u fitted the right one it shud b cold blue 4 cold and hot red one,also some times with high water pressure if the valve is only open a little the pressure will mak a noise like air open valves fully
Oct 10, 2013 | Washing Machines
Kitchenaid top loading washer makes noise when filling
Did you check the hot and cold shut off valves if they have calcium build up it might make a noise. Try replacing them.
Jun 20, 2012 | KitchenAid KAWS750L Top Load Washer
My washer will fill with water during the wash cycle just fine, but during the rinse cycle the water just trickles in. The water lines seem to be fine. What else could be causing my problem?
usually the wash is a mix of hot and cold and the rinse is just cold, that said, it is most likely a problem with the cold water supply. check to make sure the cold water valve is all the way open and the hose isn't kinked. If those are ok turn the water supply off and remove the supply lines on the machine side, you will see a screen inside the washer that may be clogged with sediment. If so, just clean it out and put it back together. You may also want to run a wash cycle on cold only to see if it fills slowly for the wash cycle. If it does fill slowly on cold you have low pressure on the cold side.
Jan 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
We have a Maytag A612 washer. Today it wouldn't fill all the way with cold water (for a cold water load). If I hit the Warm or Hot button, it resumes filling with Hot water, but I don't want Hot so I hit...
Turn off the cold water faucet.
Remove the water hose from the machine and the faucet.
Clean out the filter screen in the washer water valve.
Look in the hose for a secondary screen and clean it also if one if there.
Not all hoses have screens.
All water valves do have screens.
Sep 05, 2010 | Maytag SAV4655A Top Load Washer
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
WHEN MACHINE IS OFF DOOR IS OPEN TO AIROUT
TWO LIKLY REASONS FOR THIS
1ST IS YOUR APPLIANCE CONNECTED INTO TRAP UNDER SINK IF SO MAKESHORE ITS NOT YOUR WASTE RUNNING BACK TO MACHINE
2ND INLET VALVE IS LEAKING-TO SOLVE THAT A NEW VALVE IS NEEDED
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Why is there only hot water going in the washing machine?
the cold water valve is stuck shut inside washer.
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
The cold water will not run.
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Aug 24, 2009 | Maytag MHWE300VW Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Howling or squealing noise when the machine is filling with water
there is a restriction in the valve assembly. it is servicable so remove it, open it up on both hot and cold and clean thoroughly. replace and test
Jul 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
