Question about Whirlpool ET4WSKXS Top Freezer Refrigerator
I have water dripping from my freezer into the frige
  • 50 Answers
Drain line on back of fredg is cloged This allows the water from the freezer after defrost to go to a pan under the fredg Take the line off and blow air in to it to unclog Be carefull not to mak a big mess
Posted on Jul 12, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I work at an apartment complex with hotpoint refrigeratiors. Several of them drip water from the duct into the lower part of the frige. I defrost and clean the drain hose but that only helps temporarily....
Have you taken apart the freezer and clear the drain pan behind the freezer wall where all the water origonates from? with the refrig off and all ice build up around that drain pan melted you could use some compressed air and blow the drain from their all the way through to the end at the drip pan by the compressor.
Gene
Aug 11, 2011 | Hotpoint Refrigerators
MY ROPER FRIGE IS LEAKING WATER FROM THE FREEZER TO THE TOP SHELF IN THE FRIGE
the drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
Mar 19, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
I have condensation on the top in side of my frige that drips down and soaks my food
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 19, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
Ice on bottom of freezer and small leak on right coner
There have to be a hole to drain the water down .You might need to take the cover off tof get to drain
May 17, 2017 | GE Profile PDS22SCRL Stainless Steel...
Water dripping into refrigerator from freezer
Drain in freezer is clogged usually with ice. Unplug frige and defrost 6 hours with doors open. Pull lower front grill and check drain pan for water. If no water remove rear panel inside freezer to clear drain hole, below coils in the middle...
Mar 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a ge tns22brcblbs and there is water leaking from the freezer into the frige. the frezzer and frige are working just fine im sure the water is coming from the defrost of the freezer but i need to...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Oct 30, 2009 | GE Profile Arctica Stainless Steel Top...
I have an odor cause my fridge has been closed with no power
yes drain pan is located in the back on top the compressor....10:1 solution of water and bleach is good enough to clean it with....kills mold and mildew....also remember that if the fridge lost power and found cause a stench inside, could be held by the plastic....ive been using dryer sheets in my units to help with odors. may take a few weeks...but a new dryer sheet a week helps.
Jun 12, 2009 | Refrigerators
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Frige has water dripping in from freezer
Hi, Check the door seal.
Ice is often caused by warm, moist air getting into the freezer and condensating, then freezing.
Jun 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water leaking from inside of refrig.I think it could be Ice maker
defrost the freezer drain tube with a hair dryer
May 09, 2008 | Refrigerators
Whirlpool ET4WSKXS Top Freezer Refrigerator Logo
144 people viewed this question
Top Whirlpool Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
