Question about Dell OptiPlex GX110 PC Desktop
Cannot find primary drive 0 (C:) - Dell OptiPlex GX110 PC Desktop
    Sniper:
  • 59 Answers
Make sure the boot sequence is set to look for the hard drive first and also make sure that the hard drive is set to cable select and is the only hard drive on the IDE cable and is plugged into IDE slot 0 on the motherboard.
Posted on Nov 15, 2007
  • Brad
    Brad Nov 16, 2007
    Before you rate something as not helpful try leaving more info
Dell: Primary hard drive 0 not found Primary
Sorry, but this isn't a good sign. Drive 0 is most likely your main hard drive, and only if you have a second one would you computer ever find anything on Drive 1.
I would check the connections inside from the motherboard to the hard drive, as well as from the power supply to the hard drive.
Here's the manual: http://support.dell.com/support/edocs/systems/opgx60/en/ug/sffabout.htm#1103481
Also, if you boot your computer to the Dell copy of Windows, go through the motions of reinstalling Windows and you probably won't be able to detect any drive to install it on.
You'll most likely need to replace the hard drive altogether. Sorry!
Hope this was helpful for you (even though it was bad news)! If so, please give a rating!
Mar 09, 2010 | Dell Optiplex GX60 PC Desktop
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Dell optiplex gx110 device detection problem
I'm guessing that the computer is not booting at all. This is saying that it cannot find any hard drive to talk to. Drives are labeled in the computer code with numbers starting at 0. There are up to 2 drives on an IDE ribbon cable, the Primary, and the "slave" or secondary. So, possibilities are that your hard drive died, the power connector to it came loose, or the power supply itself is having an issue with that connection that is attached to the hard drive.
Jun 11, 2009 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
Added new drive, cloned old want new drive to be pimary
Sata's don't really have a primary and secondary, they go by the port on the motherboard their connected to.
It starts from 0 and counts up, depending on how many sata ports u have.
0 is normally the main one that the computer boots from, and its normally a different colour than the others.
So basically u need to swap the ports that the 2 drives are plugged into on the mother board
Mar 20, 2009 | Sony VAIO Digital Studio PCV-RX755 PC...
Can't get BIOS settings right
First check to see if your drive (the 160Gig) is set to master or slave. If you are going to use this drive as your primary drive (boot disk) it must be set as master, and it would be drive 0. If, on the other hand, this is a second drive, it should be set as "slave, and should be drive 1. If there is an auto-detect HDD in your Bios, try that. If not, and this machine still won't detect your HDD, you may need to download and install a Bios update, because if your Motherboard is too old, it may not recognize a 160 Gig HDD.
Feb 15, 2009 | Computers & Internet
I but a dell d600 latitud 60 hdd and 512mb,using it up to a month pluse it was tell me 0 primary hard drive not.
I assume you meant "primary hard disk drive 0 not found"? Have you pressed F12 during bootup and run the HD diagnostics? If you can't run the diags and it does not show up in the BIOS, then you have a bad hard drive.
I've seen this error many, many times on D600s.
Dec 20, 2008 | Dell Latitude D600 Notebook
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Dell OptiPlex GX110 PC Desktop Logo
335 people viewed this question
Alun Cox
