Question about Garden
My poulan riding lawnmower will not roll. The
My poulan 48 INCH 25 HP riding lawnmower model # PR25PH48ST will not roll. The neutral lever has been pulled out and all four wheels roll freely. The back roll opposite like a limited slip rearend but, will not roll together. The pully on the top of the transmission appears to be free as well. The lever on the transmission is activated by pulling on the neutral rod at the back of the mower. Any help will be appreciated
  • 218 Answers
Hi..my name is Keith..and it sounds like the neutral rod on the back of the mower needs to come out further to fully disengage the transmission so you can roll it..it should have an adjusting nut on the rod..and i would turn the nut in a couple of turns until the lawn mower will roll..i hope this will help..if not please write me back
Posted on Jul 12, 2009
How do I unlock the rear wheels, I got a Poulan Riding Mower from a late Uncle. It won't roll forward or backwards
Kevin, if it is in neutral or if it is hydro-stat, you have pulled the pins in the back to unlock the axles. the brakes may be locked up. the last two mowers i got for some reason the brakes were locked up on them both. hope this helps.
Dec 16, 2016 | Poulan Garden
Fit belt for product no 96011 0219 00
Bring your old belt to your local mower shop. They can match up a new one for you
Jan 25, 2015 | Husqvarna Garden
Husqvarna yth24v48ls leaves streaks of uncut grass
What are the size of the streaks? and where in the 48 inch swath?
Aug 06, 2014 | Husqvarna 23 Hp 48" Deck Yard Tractor
How do I engage cutting blades on poulan riding mower
There should be a lever on the dash. Push it forward to engage the blades.
May 02, 2014 | Poulan PO14542LT 14.5 HP 42 in. Lawnmower
Craftsman lt1000 stuck in neutral
The rear wheels are keyed to the axle shafts with a sqaure key, if the last owner forgot to replace one of the keys the axle will just turn in the centre of the wheel and not turn it, because the gearbox has a diff it means neither wheel will turn if either side has the square key missing, pull the wheels off and check the key is there.
Jul 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan Lawnmower
The squeal is most likely the drive belt moving against a pulley or tensioner which is frozen due to a bad bearing. This can start a fire at worst and burn through the belt at the least. You need to have someone take a look at your belts.
Jul 06, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How do you remove the rear wheel to fix flat tire?
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
May 21, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
795 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
