Question about Sony STR-DE315 Receiver
Will not power up although there is 240V AC at the input. Power switch on the front will not work
So, maybe try 120V AC......  Or can you set it for 120vac or 240vac?  Set it to where it should be.
Posted on Jul 12, 2009
How do you repair a ac switch on your fujitso siemens amilo pro v 2010
The AC switch you mention is a PSU (power supply unit).
You can by them complete on Ebay.
Part number ACADA-C7
AC input voltage 100 ~ 240V 50~ 60Hz DC output voltage 20V DC output current 3.25A Power 65W Connector size 5.5 x 2.5mm
Sep 30, 2014 | Computers & Internet
I cant find power cord for my wd 1tb portable harrd drive what voltage ac plug can i use? D33015 N3565 E101559 THOSE ARE SOME NUMBERS ON HARD DRIVE
Dear Dodgeydude
you can buy the adapter directly from http://firstmybookexternalharddrivezone.blogspot.com/2011/02/pwr-ac-adapter-charger-switching-power.html
where as the specifications are Input : AC 120-240V Output : DC 12V 2A (1.5A Compatible)
please dont forget to rate
Gagan
Mar 15, 2011 | Office Equipment & Supplies
Need a ac adaptor for a Protron PLTV-32. MODEL LU32A1A3. INPUT 100-240V 50-60Hz 3.0A MAX.Output +24V-6A +12V-3A
I found one through Powerpayless.com at http://www.powerpayless.com/ac-dc-power-adapter-for-protron-pltv-32-pltv32-lcd-tv.html. It works great!
Mar 01, 2011 | Protron Ac / Dc Power Supply For Protron...
I have a Cisnet C-28 and I'm moving to Australia. I cannot find out if the computer is compatible with 220/240v.. do you know?
Read the Cisnet AC adapter. It should say input:120-240V, 50-60Hz to work with 240v power anywhere in the world. You just need an outlet adapter for the country you're in.
Oct 13, 2010 | ZT Group CISNET A7050 PC Desktop
What power supply is needed for hp scanjet 2400
It is depends on your scanner power adapter and where u purchase the scanner from. Here if your scanner is from US then the adapter power input should be 100-120V 60Hz AC, if your scanner is from Euro, UK or Australia, the it should be 200-240V 50Hz AC, while if your scanner is from others place that not listed above then it should be 100-240V 50-60Hz AC.
But the best way is look at your adapter itself, u'll notice the power input and output from the adapter sticker.
If you lost your adapter then be sure to purchase 1 that can output a 12 VDC, 340mA, 4.22W adapter to the scanner.
YBC (/\)
Oct 20, 2009 | HP ScanJet 2400 Flatbed Scanner
Power inverter pc 500 once u put power to it the red light comes on and beeps but no a/c power
Hi there
Not a great solution but makes sense.
the ac adaptor for your alienware probably says input 240V ac 1.5Amps whilst the inverter can output 175W= 240V ac at 0.73Amps.
I am surprised it actually worked, i had to buy a 300W inverter to run my laptop. would suggest you do the same.
inverter is probably toast now anyway.
Feb 25, 2009 | Alienware PC Systems 175 Watt Power...
Hi; I Have a Dell XPS 1530 which is dull if I do not have it plugged in. I have three Targus power cords and cannot use any of them. The one that has the S35 tip fits, but only engaged...
I am showing the AC adpater specifications as:
Input Voltage Range: AC 100V - 240V
Output Voltage: DC 19.5V
Output Current: 4.62A
Power: 90 Watt
Does your adapter meet those specifications?
Although I am a proponent of Targus products, possibly purchasing an OEM adapter may solve the problem. We have successfully purchased ones available from reputible vendors on eBay at a discount.
Have you checked to always show the battery status in the system tray so that you can verify when the AC adapter is actually charging versus an intermittent connection or malfunctioning power socket?
Oct 22, 2008 | Computers & Internet
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
90 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
