Have an HVAC underflooring heating system which has been set to off but can not restart.
    Genius:
  • 1,689 Answers
Hi fiona,
if you have the service manual for the unit and if it s accessible, i strongly suggest that you scan the unit's service manual.
once the unit is opened, near the power supply, you should be able to see a 10 / 15amp fuse, if you see it blown or triggered, have this fuse replaced. these kinds of fuse is readily available from a local electronic shop.
the fuse may look like the ones below.
Once these are replaced and still did not give any restart on the unit, please consult the service manual on having the "power supply capacitor" replaced.
regards,
voodoo
Posted on Jul 12, 2009
I need a new Rehau Thermostat CT for my underfloor heating, the current one is broken. I am located in Leitrim in Ireland.
Give eBay a look, there are several for sell there.
I would ask if they are EU compatible at 50hz. I'm guessing they are since Rehau is a Canadian company but I'd check first.
Sep 16, 2017 | Heating & Cooling
My radiant floor heating suddenly stopped working. Wall thermostat is functioning normally. GFCI test is working fine. What can I check next?
Monica, There might be a break in the wire mat, you or a electrician will have to check with a digi multi meter.
Links below show how.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test underfloor heating with multi meter
How do test the resistance of my electric underfloor heating system
http://www.suntouch.com/support/troubleshooting
Testing underfloor heating
Mar 02, 2016 | Heating & Cooling
Underfloor heating not working
Along with warming up the entire area, people also look to warm up the floor, which can otherwise be harshly cold. Underfloor heating sdystem is the most consistent form as it evenly warms up the complete open space. Infrared Heater Room Heater IR Heater Magneto
Jan 26, 2014 | Heating & Cooling
Home comfort protection plan
Direct Energy knows that maintaining your Texas home is essential to your family's well-being. You can't afford to put off protection until disaster strikes, so we've created protection for your home's electrical, plumbing, and heating and air conditioning systems.
Our home protection plans deliver security by combining preventive and repair services for your home's most fundamental systems, including:
Electrical wiring
Plumbing lines
Priority scheduling with us for all appointments
Surge protection
Heating and cooling systems
Our home protection plans remove the anxiety of unanticipated costs, while our certified technicians are ready to assist you with respectful, professional service and high-quality equipment. Because we view the money you spend on home service improvement as an investment in your home and your comfort, we're committed to helping you make it worthwhile. You can choose from our plans for Heating and Cooling systems, Electrical wiring, and Plumbing lines. Direct Energy's Repair & Maintenance Essentials Plan provides annual features to catch small service issues before they become critical, $500 insurance for every repair job*, emergency customer support any time you need it, service visits with no charges and no deductibles, and so much more.
if you want protect your roof leaks so you can apply EPDM Coatings :
Watch Corporate Video
Jan 20, 2014 | Audio Players & Recorders
Underfloor heating wont stop running
Look for a stuck relay that controls the pump
Dec 30, 2013 | Hunter Mechanical Heat & Cool Thermostat...
We have a robbens underfloor heating system with a heatrae electric boiler on a floating floor system. The underflooe heating manifold has a grundfos Alpha + pump. What setting should this be at? Currently...
Venting of the system is when you re circulate the water or cooling fluid in higher speed to eliminate the air bubbles from the system.
If water circulate on a too higher rate does not have time to dissipate the heat so your floor is cold.
You need to go to 2 or even 1 depending on the length of the heating coil in the floor. Unfortunately the pump only has 2 speeds (setting 1 and setting 2) so whoever install your system had to calculate the length of the pipe for maximum efficiency. Try on 2 and if not satisfactory go to setting 1. If too hot on setting 1 then you can adjust the heat by reducing the amount of water from the shut-off volume control. It is a hit and miss situation, I know but unfortunately that is the only choice remaining now after the system is installed.
Jan 10, 2010 | Grundfos RCP-96 Recirculation Pump for...
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
