Question about Initial DTV-172 17 in. TV/DVD Combo
Power problem power stays on for a moment and shut down. power problem 5 sec power on then turn off
  • 1 more comment
  • vbrown Apr 01, 2008
  • Anonymous Aug 19, 2008
    could be the volume wire got disconnected and the unit recognizes this, so it automatically won't function until fixed ??? I"m not expert, just trying to figure why it does it. Also, if vcr not working, tv may not neither.
  • nit_pik Aug 22, 2008
    power button clicks on then off. tv won't stay on
Power stays on and then turn off.
The switch "TV/DVD/AUX/PC" to select the AV signal source do not function
everytime. If it do everything wordks normal. TV/DVD/and PC.
I think the switch is the problem. If so can you let me know the part name and part.no.
jobiel2001@yahoo.com
Posted on Sep 12, 2008
Remove back, reseat all connectors. It is a mechanical interrupt to the relay board causing the problem.
Posted on Aug 19, 2008
Computer will not start
Press power button down for 5seconds until the computer shuts down. Remove power cable, press power button down 10s. Connect cable, try to restart.
Aug 17, 2012 | Dell Computers & Internet
I have a 2007 chevy equinox. Why does the radio stay on when you turn the ignition off?
It stay on and shuts off when it see a door open signal it should remain on when the ignition is switch off for approximately 5 minutes without a door signal when it sees a door switch signal then it shuts off this is normal on alot of GM product
Aug 21, 2011 | 2007 Chevrolet Equinox LS New Cars
When I press shut down, the laptop screen gets off but the power button stays on and the laptop stays warm too. I have to press power button for 5 sec to turn this thing off. When I start it I don't...
hi, when you press the power button it'll goes to sleep mode only. You can change it by accessing control panel -> power option...
thanks & regards Anas K A
May 29, 2011 | Dell Inspiron 1545 Notebook
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
At times pc wont turn off with mouse windows shuts down but computer will turn off and on again immed
Try draining the power of the computer first. completely shut it down by pressing poweer button for like 5-7 sec. then unplug power supply from the outlet. then press and hold power button for another 15-20 sec. After that, plug back in the power cord, and turn computer on normally.
Apr 03, 2010 | Compaq Presario 5000 PC Desktop
Turn power on, approx. 30 sec later it the power
It varies as to what is actually making the TV shut down. Shorting the connectors on the A.C. plug have nothing to do with it turning back on. Its just the fact you are unpugging it for a few moments.
Nov 11, 2009 | Zenith Z19A11S TV
My red and blue crt go out and the green stays on
One or more of the CRT colors guns it dead,must be replaced.
Nov 03, 2009 | Sony KP-51WS500 51" Rear Projection...
Garmin 178C Stays on for 20 secs then turns off
I had the same problem. In your settings you can set this thing to monitor your battery's power so it auto shut down if your battery goes below 11.2 volts or so. I disabled this and it has worked ever since.
Jun 16, 2009 | Garmin GPSMAP 178C Sounder GPS Receiver
Computer keeps shutting off
The problem more likely seems with the power supply or the front power button. Donnot try switch on the computer again and again it may cause damage to the motherboard. Use the following link to pin point the problem.
http://tinyurl.com/5bbrxc
Thanks
Proton
Do remmber to rate the solution if it was helpful or fixed your problem.Thanks for using fixya
Jul 05, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Initial DTV-172 17 in. TV/DVD Combo Logo
208 people viewed this question
Top Initial Televison & Video Experts
mega_mind
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
