Question about Jazpiper MV32P 32 MB MP3 Player
My Jazpiper Hold is damage. When i power it, it displays Keyhold and power off.
Main thing is that the hold sw is broken.
From Chinedu.
0 characters
1 Points
Hold button is in off position and device still is flashing hold icon on screen
It seems the hold button has glided off the rails of its underside. You need professional help in repairing it. DON'T DO IT YOURSELF. YOU WILL DAMAGE YOUR DEVICE FURTHER.
Oct 23, 2013 | Sony NWZ-E473 4GB Walkman Media Video MP3...
My view wont do anything, when i turn it on the only thing it does is turn the dial light blue, nohing else, when i plu it in, nothing. the blue light will stay on for however long the battery lasts, is...
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Dec 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
White screen turns on but had water damage before
dude just hold the power button and the home button for ten seconds then let go of the power button but keep hold of the home button for 10 more seconds. :)
Oct 28, 2009 | Apple iPod touch
My Sony WALKMAN mp3 player won't charge
If it is a NW-A1000 I have a copy of the service manual please download it from HERE from deposit files..will be active until 29th November 2009, let me know if you need it for longer.
Goto page 9 section 4 TEST MODE.
1. Press HOLD to put the player in hold mode.
3. Press HOLD to turn hold off. You will now be in test mode.
4. Press RIGHT to display menu items
5. Press the UP,DOWN to select the POWER
6. Press RIGHT to select V CHK
7. Press the PLAY key START is displayed and all the power lines will be started.
TP9027: 1.10 ± 0.05 V T
P9023: 1.3 ± 0.1 V
TP9026: 1.8 ± 0.1 V
TP9031: 3.0 ± 0.1 V
TP9018: 3.0 ± 0.1 V
TP9028: 3.3 ± 0.1 VT
P9024: 5.0 ± 0.2 V
You can check these on the main board to see it all are present if one is missing this will be why your walkman wont hold any charge.
Sep 23, 2009 | Sony MP3 & Digital Media Players
My iPod Touch is disabled/"Powned" and I have no clue how to fix
Your ipod has been jailbrokan and apple has detected that so they disabled it.
Jun 13, 2009 | Apple iPod touch
Download the firmware updater from the mobiblu site
Install the software, connect the player via the USB cable, set the switch to hold and run the updater. When it is finished, stop the device and disconnect it. When you power up, it will be back to factory settings (any data/music will be erased).
Aug 12, 2008 | Hyun Won mobiBLU DAH-1900 MP3 Player
Samsumg YP-U2 player constantly on HOLD. Help.
I had the same problem - culprit is a broken hold switch. You can return it for a refund, or so what I did:
I fixed it by prying off the hold switch, and jamming a small flat-head screwdriver in to try and slide the 'switch' back to the 'off' position. Took a while, and it permanently breaks your hold (which is broken anyway making the thing unusable), but it worked.
Just be careful not to smash it when you get really frustrated! It took me a solid 30 minutes to finally get it.
Apr 15, 2008 | Samsung YP-U2X Digital Media Player
My sansa e250 ask me this
1. Put Lock on.
2. Push and Hold Both Rec and Power buttons while the power is off.
Then message should show saying: " Welcome to Recovery Mode"
Mar 17, 2008 | SanDisk Sansa e250 MP3 Player
YP-U2J Samsung mp3
just start mashing buttons....this happened to me and after a moment of worked!
Nov 20, 2007 | Samsung YP-U2X Digital Media Player
Mp3 player
if it isn't the 'hold' switch then there is something wrong internally. if you wanna try... sandisk ran me through these troubleshooting steps, hope they help. do one at a time and see if you get a result -Reset device take out battery hold power button for 30 count put battery back in turn device on. -Upgrade firmware Go to website, download firmware update This was the URL at the time of writing this or try Install according to instructions. let the device reboot. -Format memory. turn hold switch on, orange should be visible hold pause/play button and press power. click forward button when the screen comes up. let this run. after reboot flip the hold switch off.
Aug 13, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Jazpiper MV32P 32 MB MP3 Player Logo
18 people viewed this question
Top Jazpiper MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Jazpiper MP3 and Digital Media Player Expert? Answer questions, earn points and help others
