Matsunichi 1TB USB 3.0 Portable External Hard Drive, Black DM256-BK-1TB Logo
'Bull' Biskit Posted on Jul 29, 2015
How to regain 1TB capacity ?
Backed up 50GB of Windoze XP data. Now it says it is only a 69GB ext drive ???
Roger Currier
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Aug 02, 2015
Roger Currier
Contributor
Level 1:
New Friend:
Answers
18
Questions
Helped
3276
Points
53
Suggest you save any data on the disk then do a full reformat of the disk, not the quick format.
I have a simpletech-Fabrik 1TB ext. HD. Where can I find software for this HD? My previous laptop data was backed up to the Ext HD. but the software was lost when that laptop crashed and I have lost the...
Most, if not all external hard drived do not need a driver. Connect the drive and power, turn it on. There is no need to use the backup program that comes with the drive. Use Windows backup that comes with Windows 7.
If my external hard drive is 1000gb how come it only showing 931gb what has happen to 69gb
Check the drive partitions. You probably have a small partition that is separate from the main partition and it contains drivers and files needed for various operating systems to use the drive properly. It is best if you use drive partition software for this but that is the most common reason for it to show a difference. The second most common reason is the drive wasn't formatted to capacity. I have this drive and I know for a fact the backup software and and driver software are stored on a small partition on that drive which reduces the amount of the main partition.
1helpful
My computer tells me that Seagate Replica 250gb is unpluged and that it has not backed up for 33 days - Also should the blue light be blinking or should it remain a steady blue
1.check the backup software and see the schedule status for it
2. When data is be transferred the light should be blinking
When idle the light should be steady.
I have bought Western Digital 1TB external hard drive. but my window xp is not finding that hard dirve. how can i conect and find on my xp.
You will probably need to install the drivers that came with the drive for Windows to see it. Check out the instructions that came with the unit and it will walk you through installing drivers and connecting the drive to your computer.
I recently reinstalled my OS (Windows XP Media center edition). Ever since i reloaded the OS my WD My Book Home edition 1TB external HDD stopped showing up in the windows explorer as a drive letter. The...
I can't diagnose the drive issue... but I can offer a reliable and trustworthy data recovery solution that I had to use a year ago. It's Seagate's do it yourself data recovery and will work on your WD drive. So if you can't resolve the issue otherwise, consider this as a recovery option...
https://services.seagate.com/diysoftware.aspx
Western Digital 1T MyBook keeps crashing
it seems a problem with the driver, try plugging it onto a different computer. If that works, reinstall the driver.
5helpful
2answers
Computer freezes on start-up when western digital 1tb external hdd plugged in to computer, computer starts fine with it unplugged. The hard drive can be plugged back in after start-up.
This is a known problem with these drives. Disabling USB legacy support in your Bios should solve the problem., it did in my case but at the expense of not being able to boot from a USB device. Definitley a problem with their enclosure or drive.
Ken D
2answers
Ext. Hard drive no longer recognised by computer operating on XP
Check in the device manager to make sure the drivers are still there.
1TB Cavalry eSATA drives
DID you chk the data transfer speed ??
Top Matsunichi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Matsunichi Computer and Internet Expert? Answer questions, earn points and help others
