Question about Dell W2600 26 in. LCD Television
2600w Wont turn back on after turn off I can freeze a small solid state device on the board and it will turn on every time.
  • 1 more comment
  • Anonymous Nov 22, 2007
  • Anonymous Nov 27, 2007
    wont turn on after being switched off unless i unplug it from the wall for a lengthy period of time
  • dskeene Mar 10, 2008
    same problem, could unplug from wall for awhile (a long while) and it would turn on eventually. now, well, will not turn on.
Need replace electrolitic capacitors in power board. right on top wen you open back cover.
Posted on Dec 04, 2007
Fix samsung lcd screen not turning on. Sound works.
You have a an intermittent anomaly - nasty situation to fix for obvious reasons. You can live with it and wait till sucker finally goes for good.
Your problem lies with no backlighting (inverter board) or the T con board responsible for the images you see on the screen.
You are on the right track because caps and resistors can have dual personalities - both are also heat sensitive. Solid state devices either work or do not work - period.
Or you might have a hair line crack on a board. Using a small directional fan and giving the respective board the mother of all blow jobs you can perhaps localize the heat issue. Good luck.
Feb 14, 2016 | Samsung Televison & Video
Sony vaio vgn-fz21e upgrade solid state drive
If you are looking to upgrade to a solid state drive, or already have a solid state drive and just want to upgrade the size, you will have to purchase the new drive, when you receive the drive you will have to turn the notebook over and there should be a rectangular panel underneath about 5"x3" inches which can be removed by a small Philips head screw driver, remove the panel, carefully remove the hard drive installed, and install your new drive. Put all the parts back, and then you will have to do a clean install of an operating system on the new system. Good luck!
Aug 17, 2012 | Sony VAIO Notebook
Factory restore fail due to i/o device error
This input output so your keyboard mouse or some other device you have on or in your computer is bad or going bad, try unplugging them one at time until you find the problem, This can also be your video card or sound card, Do the easy things first before you open your machine.
May 31, 2012 | Acer Aspire 1691WLMi Notebook
Hobart handler 140 mig welder gas wont shut off
Looking at the Hobart manuals, that is how they set them up at the factory.
One way to make a change to that is to wire in a solid state relay or solid state Triac and pick up an energizing voltage off of location RC2-1 or RC2-2 on the control board when the trigger is pressed, or as an alternate location from the feed motor through a resistor and rectifier. Once you know if the voltage goes low, or voltage goes high at your point of signal, you pick the contact you want on the relay so when the wire is feeding out, the gas is flowing. and when it is not feeding wire out, the gas is shut off.
Dec 31, 2011 | Hobart Welding Tools
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Whirlpool GC5SHEXNS03 started making hissing sounds and could hear water draining into pan at bottom. Then noticed that neither freezer or 'frig are cooling and motor not turning on. I turned it off/on but...
Seems that perhaps your unit stopped in a defrost cycle. If this has a solid-state control board, it's probably the board that has failed. If it's the old style without a board read on.
All frost-free refrigerator-freezers with exception for the ones with solid-state control have a thing in the system called a Defrost Timer. The thing is a little clock of sorts that tracks accumulated running time. Every 8 hours of run time the thing cycles through a defrost cycle. The defrost cycle is necessitated by the humidity that forms ice crystals on the freezing coils, if the frost is not eradicated it can build up to the point where no air flows over the coils to chill the inside of the box. (it may keep the freezer cold but no air goes to the fridge part. If completely solid neither cools) Most timers are located on the front of the machine, behind that removable grille under the door. Sometimes it's found in the refrigerator behind a plastic cover. The timer has a round hollow shaft through it, and can be turned with a screwdriver (screwdriver should be 1/4 inch wide and should not fit inside shaft). In your case since the compressor is not running, give the shaft a slow twist until a click is heard and the compressor starts. If the compressor does not start you may have other problems. If it does then get a replacement timer.
Even if you don't attempt your own repair this is good to know. Also know that the defrost timer is not an expensive repair if you have to have some do it.
Jul 14, 2009 | Whirlpool GD5SHAX Side by Side...
Samsung TV Popped and wont come back on
Jun 30, 2009 | Sanyo DP42848 LCD TV
Hampton Bay Ponte Vecchio ceiling fan light flickers
Try swapping out the bulbs and see what happens. There are bulbs made specifically for ceiling fans that have heavier duty filaments in the bulbs, or you could use compact fluorescents. The warning about using a solid state control was referring to using a solid state dimmer at the wall switch.
Mar 01, 2009 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
Dell W2600 26 in. LCD Television Logo
113 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
