Question about Chaintech 9CJS ZENITH Motherboard
No sound and not reading sata drive
Hi! my windows crashed the other day, I had to reinstall everything, after installing windows, I went online to reinstall all the programs for the ct9cjs zenith motherboard. Now I have no sound and will not read my sata harddrive. I have three hard drives, it's only reading the first two which are not sata. What can I do to fix this or is there a fix? Thanks PT
  • Daddyok Nov 16, 2007
    Hi! my windows crashed the other day, I had to reinstall everything, after installing windows, I went online to reinstall all the programs for the ct9cjs zenith motherboard. Now I have no sound and will not read my sata harddrive. I have three hard drives, it's only reading the first two which are not sata. What can I do to fix this or is there a fix? Thanks PT ( I did go on the site for new uploads, I also checked to make sure every thing was plugged in. It's still not working. It crashed when I installed the ZoneAlarm system.) I still need help. Thanks! DaddyOk
Throw computer with its Vista operating system out the window. Microsoft is NO help at all.
Posted on Jan 02, 2010
  • 196 Answers
What was the cause of the crash? Could it be related to the SATA drive or the sound problem?
You may need to enable SATA in the BIOS. Look closely at the BIOS options.
In Control Panel/Hardware/Device Manager/Sound look to see if the sound driver is installed. If not, look on the manufacturer's site for the driver and install it.
Make sure the sound is not muted and the hardware connections are correct.
Posted on Nov 16, 2007
Old machine, trying to rehab for daughter. Turn on, seet Toshiba screen, then see "Disk read error, cntrl+alt+del to reboot"
You have one of two problems. Either your operating system crashed and you will need to get windows reinstalled on the computer or your hard drive crashed.
If the hard drive crashed you will need to replace the hard drive first and then also reinstall windows.
In both cases it is needed to reinstall windows.
This is probably something a computer technician should take care of.
Mar 06, 2011 | Computers & Internet
My gateway laptop doesnt read the hard drive and i cannot reinstall windows vista
Sounds like a crashed hard drive, swap it out with a new one.
Take your old hard drive with you when you head out to buy a new one to make sure you get the same kind (they're only two kinds for the most part - IDE / PATA has 40 pins and SATA has two L shape connectors.
Hope this info helps!
Oct 10, 2010 | Gateway ML6721 Notebook
My windows crashed. When computer starts and tries to raise windows it restarts. Tried everything, can't access password protected account where important informations stored. Help
To access the data, try removing the drive from the computer and installing it as another drive. There are several external docks that accommodate drives for this purpose.
If the drive is IDE, try an IDE enclosure. If the drive is SATA you can use a SATA usb dock or an enclosure.
You could try repairing Windows using the repair mode. Tap F8 as Windows starts.
You can try booting in safe mode. To start in safe mode, tap the F8 key quickly as Windows trys to start.
Dec 13, 2009 | Intel Computers & Internet
My gate way went down now it tell me no operating system found what do i do
Do you have a cd/dvd in the drive? (a non-system disk)
Try to boot into safe mode.
Try to restore to an earlier time.
If unsuccessful ... you may have to reload the operating system
Oct 21, 2009 | Computers & Internet
Computer crashed. Computer specialist restored drive. now cannot boot windows. Used restore disk. Did not work. computer boots dos screen then shuts down. boots again then shuts down.
Sounds like a Windows issue. Depending on how valuable it is to you to get your data off the drive, I would suggest buying a new hard drive (they are fairly cheap these days), installing Windows on that. Word of advice: Remove your old drive when doing the Windows install, so as not to accidentally select the hard drive your data is on. Once you have Windows installed, shut down your computer, remove the power cord, and install your old drive on a separate IDE channel or SATA connection. If your PC still tries to boot to the old drive, change the boot order in your PC's BIOS.
Aug 10, 2009 | E-Machines eMachines Desktop PC
Vista boot manager missing
Your hard drive is bad. It will keep crashing until you replace it.
Mar 25, 2009 | Dell Inspiron 1420 Notebook
Laptop wont start. Told hard drive has crashed.
Sounds like you need to replace your hard drive. First you need to figure out what laptop model you have, then look up the specifications on the manufacturer's website to see if you have an "IDE" hard drive, or a "SATA" hard drive. Purchase a replacement hard drive, and install it into the computer. Then reinstall windows xp and you're good to go again.
Dec 13, 2008 | Computers & Internet
Installing 4 SATA hard drives on the GA-8KNXP mobo
check motherboard manual it seems you may have the sata drives plugged into wrong number socket they should have numbers on them sata 1 etc
Jul 28, 2008 | Gigabyte GA-8KNXP Motherboard
Installing photo express
Knight, as i have understood when you reinstall windows XP, it can't load photo express. This is probably because you had installed Photo express in your the same drive you had installed your windows. When you reinstall windows that drive is completely formatted and thats why it can't load the software.
Make sure you install photo express in some other drive. You can also rip the setup on a dvd so that you could reinstall it when your window crashes. For window crash, you might like to use an antivirus software like Avast.
I hope that must solve your problem. You might also like to read Photo express manual for specific instructions if it doesnt work.
Nov 22, 2007 | Adobe Photoshop 7.0 for PC
Chaintech 9CJS ZENITH Motherboard Logo
187 people viewed this question
Top Chaintech Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
