Question about Nokia 6600
Crystal ic - Nokia 6600
CAN'T ADJUST COLOR
Either bad color crystal (need an oscilloscope) 4.5mhz. Check for 5v on pin one of e-prom ic, If low, bad e-prom ic, If 5v its good, bad y-c deflection ic
Oct 25, 2011 | Philips Magnavox 27MS343S 27" TV
Touch pad not working
Hello And Welcome to fixYa!
There is a crystal type IC that operates. the working of the touch sensors. The crystal had gone mal function and needs to be replaced...
Concerned.
Jun 28, 2011 | Sony Ericsson K850i Mobile Phone
Unit not powering up
Probably Laza got into the system . Try luring him out with some small children ?
Dec 21, 2009 | Pioneer VSXD814 Receiver
I dropped my iphone 3g on the ground at about 4 feet. and the screen is super dim. and i can cant see the words. but the phone is still working. the screen is just really dim
Yopu got a problem with your crystal IC for the LCD, it probably mis-aligned from solderd, bring it to a technician andhave them Re-heat the crystal IC at the back of the LCD screen
Nov 09, 2009 | Apple iPhone 3G Premium Polycarbonate Red...
Nokia n70 whitedisplay
the display ic is of nd the LCd is ok,  so checjk the crysta l iC  o the flash,, i conclude maybe the crystal IC has the problem
Apr 26, 2009 | Nokia N70 Cellular Phone
NO SIGNAL. SCREEN IS LIT WHITE.
Try to check cable connector from main board to controller board, Check entire main board resolder voltage reg. ic, check MCU IC, Scalar IC, EEPROM IC and Crystal Capacitor.
Nov 13, 2008 | AOC LM 520A 15" LCD Monitor
Hitachi 46w500
Good Day, reddragon244;
You may not be able to see the cold solder connection, just go ahead and solder both connections on the Crystal.
Good Luck, big IRISH.
Aug 19, 2008 | Televison & Video
3100 network sometime receive nd sometime nonetwork
You need to change the Signal amplifier, refresh UEM ic..hope could help..
Aug 03, 2007 | Nokia 3100
No color, only black and white
There are no bulbs inside this set to replace. This TV set is all solid state. That means it uses transistors and IC's to work. If the color is not there you could have a bad tuner assembly in this TV set and to replace that would cost you more then the TV set is worth. Sorry. Good Luck
Jul 18, 2007 | RCA BD20TF10 20 in. TV/DVD Combo
Nokia 6600 Logo
27 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
