Question about Car Audio & Video
Amp stopped working. gets power but protection light wont shut off checked connections and fuses. was part of a dual amp install 2 audiobahn a4002t's brigded @ 4ohms pushing 2 12'' cvr's
  • 32 Answers
Did you use a capacitor? and check your ground wire. might need a bigger dround.
Posted on Jul 12, 2009
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
My amp and stereo keep shutting on and off.
It would make sense that if your radio turns off, your amp will shut off too since its likely your amps remoae power signal is delivered via the light-blue wire from your radio.
so the question is, why is your radio shutting off.
Odds are your using an aftermarket radio and your ground wire is poorly connected.
check it.
May 03, 2011 | AudioBahn A4002T Car Audio Amplifier
A4004T AUDIOBAHN HEARTBEAT FROM AMP WITH BLINKING POWER LIGHT BUT NO PROTECTION LIGHT. UNPLUG SPEAKERS NO PROBLEMS. TRIED NEW WIRES, NEWER BIGGER GROUND. SUPPLIED WITH 40AMP FUSE NEAR BATTERY AND 2 20AMP...
If you disconnet you speakers and there is no problem, Then it's your speakers.
1. try your speaker wire in one port at a time (may have blown one of the outputs)
2. Check the speaker connections directly on your speakers (not loose or damaged)
3. try a different speaker all together and see if you get sound etc.
4. try a different wire from your speakers to your amp (wire may have shorted out or have breaks)
Hope this helps and please rate. If you require further info please comment and I'll get back to you asap
Mar 19, 2011 | AudioBahn A4004T Car Audio Amplifier
I have a audiobahn a4002t. it will not power off when the key is off and removed. i have even tried disconnecting the remote wire and this does not help. i have tested the radio for functionality of the...
More than likely the amps internal relay that is powered by the remote lead has shorted open, allowing the amp to connect power and ground regardless of the remote signal.
Should be a relatively inexpensive fix at an electronics repair shop.
Jan 03, 2011 | AudioBahn A4002T Car Audio Amplifier
My protection Light came on. How do I get it to go off?
audiobahn went out of busnes 5-8 years ago i wold replace the amp with a class d diferant brand
Jun 17, 2010 | AudioBahn A4002T Car Audio Amplifier
Audiobahn a4002t beats steady and alternates between power and protect mode. need help.
That usually happens when your amp keeps clipping and basically doesn't have enough juice to push the speakers. You can try to ground the amp better, preferably to the chassis, and you can also get a capacitor and see if that helps keep the steady power going to it. There are those times that the amp is just getting old, but I would try these simple solutions first. Hope this helps.
Dec 31, 2009 | AudioBahn A4002T Car Audio Amplifier
Remote bass control short
It Could be Eiher Problem Make Sure The Remote our using is thew same brand as the amp its plugged in to
May 27, 2009 | AudioBahn A4002T Car Audio Amplifier
Audiobahn A8002T
The most common cause for an amp to go into protection is shorted output transistors. To eliminate other possible causes, read through the following page.
Troubleshooting - Amp in Protection
Let me know if you have any other questions.
Jul 23, 2008 | AudioBahn A8002T Car Audio Amplifier
Audiobahn A4002T that keeps popping fuses
Does it blow them immediately when inserted, only after the headf unit is turned on or only at high volume?
Jun 07, 2008 | AudioBahn A4002T Car Audio Amplifier
Wierd stopped working audiobahn a2300hct
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Car Audio & Video Logo
276 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
