You should be able to turn it by hand or with a socket and ratchet broken crank means broken car if you broke crank which is rare you would not have a running engine sounds more like stretched timing chain if it feels sloppy
If your crankshaft was broken, you wouldn't be going anywhere. Could be crankshaft pulley is also a dampener and often times they separate from each other, replace pulley/dampener, could be rods or main bearing problem. Do you hear any clunking or knocking noises with the engine running?
SOURCE: Crankshaft pulley (vibration damper) moved forward.
the pulley is also a dampener often times they seperate from each other. replace pulley/dampener.
SOURCE: 96 Nissan maxima -Loud Belt-like noise
try some belt dressing (spray in a can) you can get at any auto part supply,it worked for me
SOURCE: Crankshaft Woodruff Key Removal
You are correct, this key does drive both. While I have never tried to remove the keway with out both pulley and lower sprocket you may be able to (my gut says no but anything is worth trying once) I'd position the keyway at the 12 o'clock postion and with a good pair of needle nose pliers see if the key will roll out as you pull up and away with it. If it will not you'll of course have to remove the front of the engine and pull the timing belt, if over 60K miles on belt go ahead and replace with new.
I hope this may have assited and good luck!
Tom
SOURCE: The serpentine belt pulley on
yes, you need a new dampener. You will need special tool--a puller. the procedure from autozone.com is as follows:
Fig. Crankshaft balancer removal-3.1L engine To install:
