Question about Acer Computers & Internet
Just replaced my power supply in my HP pc. now my acer monitor is "not receiving a signal from my pc.
  • 34 Answers
Check the memory and video card maybe it misaline
Posted on Jul 12, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Replaced power supply and viedo card stil no signal on monitor
Disable on-board video or check to see if you power supply has the wattage to run the video card..
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Apr 14, 2014 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Acer ASpire M1100 shows No Signal on monitor
Any time a monitor says "no signal" that message is originating from the monitor itself, and not from the computer. A monitor in a room by itself with no computer will say "no signal" for a brief time, if it is turned on. So, if you have tried other monitors also with no luck, then the problem is either the video adapter of the computer, or something that is keeping the computer from booting in the first place (power supply, hard drive, memory, motherboard). A power supply can be tested with an inexpensive tool. Everything else needs either a swap out with a known good stand-in, or else an expensive tool to know if it works.Does the fan come on when you turn the computer on? If so, maybe more likely to be the motherboard, hard disk, or memory. If not, more likely to be the power supply.
Feb 02, 2012 | Computers & Internet
Acer Monitor V193W has no signal
There are 2 basic reasons for the "No Signal" message.
  1. Loose video card inside the machine- if you're machine didn't come with on board video or if you are using an independent video card instead of on board video, the card can unseat at times, either due to movement of the machine or pulling on the video cord
  2. Loose connection between the video cord and/or monitor and/or machine. Unless the plugs on both ends are secure (including tightening both screws to prevent loss of connection), the cord can dislodge just enough to interrupt your connection, causing a "No Signal".
If neither of these is the case, try hooking up a different monitor (if equipped, you can use an HDMI cable to your TV) to see if the "No Signal" message persists.If using a different monitor works, the issue is your Acer Monitor.
Dec 07, 2011 | Acer Computers & Internet
I am not receiving a signal. I have changed cables from my computer to the monitor. I have unplugged, allowed to rest, then plugged in again.
Does it do the same with another PC, need to narrow down to either the monitor problem or the PC video card problem first. Please post back what you find so we can help you further.
Most common failures in the ACER and other LCD monitors are due to bad caps in the power supply.
See pictures here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | Acer AL1917W LCD Monitor
Acer al1922 monitor no signal:
If it does the same with other PC then you need to open it up and first thing to look for are bad caps in the power supply, see example of failed monitors due to bad caps, transistors, transformers, lamps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside, and always replace with good quality caps such as PANASONIC FM or FC series from DIGIKEY.
Mar 23, 2010 | Acer AL1916W 19" LCD Monitor
Acer 1916W No image on screen any more.
As you can see at photos I post on photobucket.com, you will see mot monitors are bad due to bad caps. http://s807.photobucket.com/home/budm/allalbums
You should replace them with LOW ESR 105C caps, I use PANASONIC FM or FC series from DIGIKEY, otherwise they will not last.
Feb 06, 2010 | Acer AL1916W 19" LCD Monitor
We are getting a No Signal on our monitor,
it should be motherboard problem.
try to check it nearby service centers
are you able to hear any beep sounds
pp
Nov 21, 2009 | Acer Aspire L100 PC Desktop
Monitor won't come on
Check the power cable of the monitor make sure everything is properly connected.
May 10, 2008 | Acer AL718 17" Flat Panel LCD Monitor
Install new power supply?
The monitor is not receiving any signal from the PC. When you push the power button ON, is there any activity on the PC (LEDs on, power supply fan, etc) or it's just dead ? In this case, yes, the first thing to check is the power supply.
Jul 06, 2007 | HP Compaq Presario 6430NX (DA237A#ABA) PC...
Open Questions:
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
