This problem should be removed because:
Problem with LG 42LG30 42 in. HDTV LCD TV
connect My pc via 15 pin RGB cable to LG lcd tv but no sound
I Just connect My pc via 15 pin RGB cable to LG 32R50xx lcd tv,it show the picture but no sound.
Than i connect the audio cable to the tv use 3.5mm j.
it only has sound when I use input and select AV3 but no pictrue this time.
So the tv has either show picture when I select Input RGB
Or the tv only has sound when select AV3 with the aduio cable.
Please tell me how to made it has picture and sound together?
thanks
Ken
Suggested Solution (1)
You probably need a audio cable that runs from the pc audio out to the TV audio in. Radio shack has them so do a lot of hardware store and best buy.
BLANK TV
My 5 yr old son attempted to turn the television without the remote and the TV went Blank no sound no pic. This happen to me before but i...
I Just connect My pc via 15 pin RGB cable to LG 32R50xx lcd tv,it show the picture but no sound. Than i connect the audio cable to the tv...
what type of audio jack rgb/dvi in on rear of lg
what type of audio jack rgb/dvi in on rear of lg 50ps3
Need the manual to find
Need the manual to find out how to setup AV3 & AV4 as Component input, or if it is compatible with standard component input. Does not...
My Pace DS230NNZ (Sky Decoder)
My Pace DS230NNZ (Sky Decoder) will not transmit Component 1080i Progressive Scan video to my Phillips 36PW9527/79R AV3/AV4 high definition...
Tips for Helping wisechen888 With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
no sound on the left speaker of my LG LCD...
I tried adding a home cinema through the RED & WHITE jacks but there is no sound coming out, when I tried the...
Logik L19LID648 turns on but screen blacks out
this was caused by 2 capacitors on the invertor power board - namely a 220uf & a 1000uf - replaced with same...
white screen problem !! at the point which they...
fixed mine by applying wrapped neoprene foam strips to the ribbon flexi cables at the point where they meat the glass...
red strips
sound preserved forms seen in background
Fix-O-Meter
426
426 people viewed this problem
- 0 people are following this problem. Be the first!
Top LG Flat Panel Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
