Question about Intermatic Hardware & Accessories
How do i remove it from my wall
How do i remove my intermatic timer / light switch from my bathroom wall?
  • 3 Answers
Simple remove the plate then there are two screws that you need to unscrew then you pull the whole thing out.
Posted on Jul 14, 2009
What is the intermatic e 1020 used for just moved into a house andits in the bathroom and makes a lot of noise.
The E1020 timer is reliable heavy-duty 24-hour on-off analog timer with replaceable trippers and manual override, rated 12 amps.
This timer replaces ordinary single-pole on-off switch.
Timer has extra white wire that connects to white neutral wires inside box to run timer mechanism, while mechanical single-pole switch does not need this wire.
I don't know what it is doing... maybe running the vent fan periodically, or turning on attic vent fan?
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#E1020
http://waterheatertimer.org/How-to-set-timers.html
For same timer, with less noise, install E1100-1200 aka the KM series in-wall analog timer. Or install digital in-wall timer, or replace timer with on-off switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 11, 2012 | Intermatic Timer E1020, Single pole/single...
I have a wall timer which activates a bathroom fan. It was switched on this morning and now it cannot be switched off. How do I switch it off. I do not know the model number
Timer probably needs to be reset, or possibly timer has gone bad or battery has gone bad.
More information is needed.
Let's identify timer, and then possible solution can be given based on that.
If you bought timer locally, what store did it come from?
Add a comment at any point.
Also open timer door to see timer buttons:
Open following link to see Intermatic timer buttons:
At bottom of page are links to more timers.
For example Sylvania, Tork, GE, Utilitec, Aube, Leviton
Aug 30, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I do not have an instruction manual for the Intermatic E1400WC timer switch and I can't figure out how to program the on/off times.
Intermatic makes heavy duty Ei400 series 1HP 120V or 240V countdown timer that can be wired for single-pole and 3-way.
Open following link to identify Ei400 timer and download manual:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#Ei
Coundownt timers are used to control fans and lights that need to run certain length of time, and then turn off. For example bathroom fan or whole house attic fan
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Solar Intermatic Digital Wall Self...
I do have and Intermatic ET724 timer and it has stopped working. I don't think it works with battery as it is attached to our bathroom light switch . any luck to fix it? or it is time for a new one??
That's a good old timer.
Grasslin ET724 in-wall timer is no longer available.
http://www.amazon.com/GRASSLIN-ET724-Grasslin-Et724-Electronic/dp/B000BHCFT6
There are several programmable timers on the market.
Intermatic EJ500 is simple to install and program. Works on battery but is for incandescent light only, not for fans.
http://www.amazon.com/Intermatic-EJ500C-Indoor-Digital-Switch/dp/B000E8VAIO
GE 15071 from Home Deport is inexpensive replacement and works with fans, lights.
Needs no battery. Uses electric circuit to operate clock.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
More timers:
http://waterheatertimer.org/Programmable.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 20, 2011 | Intermatic ET724-A-CS - 24Hr. and/or 7-Day...
I have a wall-switch Intermatic Timer Model 885L that has become too stiff to turn itself off automatically. Can these be lubricated by WD-40 safely???? Or what is best fixit???
I am unable to identify Intermatic 885L
Add a comment with clear description of timer so I can identify and help.
With mechanical dial timers, once the motor begins to slow down, then motor overheats and burns out. This is true for all electric motors, and eventually all electric motors stop working.
Power pack yard-light transformers, in-wall timers and plug-in type timers are not repairable, even with WD40, because the motor has already overheated.
These timers are replaced with new timer.
However if you have a power pack, since this timers is expensive, you can buy cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
With direct wire mechanical box-type timers that are used for parking lot lights and pool pumps, for example T100 series 120V and 240V timers, the clock motor is replaceable. These small motors cost $16 to 60 depending on clock.
Again, add a comment with clear description of timer so timer can be identified for certain.
I can also post the manual if available, and post links to sellers of similar/same timer if replacement if necessary.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
http://www.aplussupply.com/intermatic/timer.htm
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 31, 2011 | Intermatic Hardware & Accessories
My intermatic switch won't turn off the outdoor lights. It covers the original light switch. It has a plastic cover with a extention that press smaller button underneath that says no op see inst. Please...
I answer questions for free.
I specialize in timers.
According to Intermatic, they no longer make the light switch timer.
I cannot find the instruction manual on Intermatic.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
From my experience, I suspect that the timer is old and does not function any more.
If this is not correct, add a comment and I will answer
Hammacher makes a wall switch timer. $40
http://www.hammacher.com/Product/78709?promo=Electronics-Safety-Security&catid=106
Intermatic also makes another timer that is simple to operate.
It is called the EJ351 but it has to be wired into the wall.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
be3a610.jpgEJ351 cost $25 http://www.nextag.com/intermatic-timer-ej351/stores-html
Nov 01, 2010 | Hardware & Accessories
How do you set this timer
http://www.intermatic.com/products/timers/in-wall%20timers/24-hour%20mechanical%20time%20switches.aspx
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/e1020%20-%20english.ashx
Timer shown is E1020 or E1010
This timer wires into a wall box
Grasp time dial firmly and pull until it comes free from timer.
Remove all silver ON trippers and brass OFF tripper using pencil or paper clip
Program the timer by inserting trippers
The minimum set time for this timer is 1/2 hour
OFF trippers should be spaced at least 2 hours apart from another OFF
ON trippers should be spaced at least 2 hours apart from another ON
Push time dial back onto timer
Current time lines up with time line located at top of timer dial
Next to the time line is the manual override.
Use manual override to reverse the timer program, so if lights are OFF, manual override will turn them ON.
Oct 28, 2010 | Heavy Duty Intermatic Wall Switch Timer...
Didn't sve the instructions on how to program??? I have a model EJ351
The EJ351 instructions are posted on-line at Intermatic
Intermatic shows all their products and manuals on-line
The instructions are straightforward
If you have a problem, please re-post another question
Oct 20, 2010 | Intermatic Programmable 24 Wall Switch...
Hardware & Accessories Logo
251 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
