Tv is very loud when volume bar is on one(1).
    Genius:
  • 1,074 Answers
First of all you had not stated the brand of your tv.if your are not a tech have your tech check into the aduio circuit for a damage audio ic or have him change the eprom both of these component controls the audio circuit.good luck
Posted on Jul 12, 2009
How to lower internal volume on tv
You can't but you can get round it. We have the same problem at work.
You have to stop using the internal speakers and buy a sound bar instead that provides more control.
There are a couple of ways of wiring a sound bar and the cheapest ones plug into the external/headphone socket and others plug into the coax, or component connections.
Sep 08, 2014 | Westinghouse Televison & Video
Low volume
If it's a new TV, then it might just be as high as it goes. A lot of HDTVs don't come with great speakers due to the small flat feature of the TV not allowing anything better.
You will have to get external speakers for the TV to experience better sound.
Here is a great sound bar that is well priced. http://www.amazon.com/Vizio-VSB205-32-Inch-Theater-Soundbar/dp/B004VGI2EK/ref=sr_1_2?ie=UTF8&qid=1359416740&sr=8-2&keywords=32+inch+sound+bar
I've personally heard that sound bar and they are surprisingly loud and hardly take up any room at all.
Jan 28, 2013 | Polaroid TLA-01511C 15 in. LCD Television
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
My Sony Trinitron volume goes from mute (1 bar) to loud (2 bars) - can increase to even louder but can't get low or medium volumes. The lowest volume is too loud for normal viewing. Any ideas about what I...
Hello
If you have some idea about the working of your TV, and some service experience you can do it by yourself. Your TV has electronic volume controls. That means, a gradual voltage rise or lower does the volume to go up or down. This voltage variation is done by an Ic which we call it as "System Control Ic", that every modern TV has; but differ in their type and number. You must know how to follow the schematic diagram of your tv to get the exact point from which the voltage orginates, and which point regulates the same.
At present there is some voltage, say 0.23VDC or so, remains at that control point even if you turned all the visual controls seem to be off; and that voltage suddenly goes up; say 3.05VDC or so when you adjust the volume to the near mid stage. Further saying 3.05VDC must come only after you have turned the volume bar to extreme high. Now you are listning your tv at is 1/4th volume at extreme low I thinks.
Looking for fault at system contol section must be done with patience, and should have schematic diagram of it, and some sort of skill. It is best for you to get service of an experienced service personal, otherwise the the faults will be rise in numbers. All sony tv has complex schematics even go to pages on a book, and have some difficut to follow even an experienced one you know. So think a little better and do the needy.
If you have confidence that you can reach the the above said points, contact me at my mail address which is given below. I will guide you. You must have the schematic digram of your tv also beside you. Ok.
gopakumarg43@ymail.com
Oct 19, 2010 | Sony FD Trinitron KV-28FQ75 28" TV
Master volume to high
what kind of tv is it i work for fios and am willing to help you.
Dec 03, 2008 | iLO 3200 32 in. LCD Television
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Voume problem when playing dvd
the problem try to reprogram the memory ic
May 13, 2007 | Samsung TXG2746 27" TV
Samsung TXE1370 13" TV - volume out of control
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
Feb 25, 2007 | Samsung TXE1370 13" TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
