Question about Samsung Televison & Video
Samsung SP50L2HX turns itself off, hot or cold! It can go for hours or just five minutes. It can turn off once or again and again in one viewing. The lamp and temp lights flash and the only way to have it working again is tourn it off on the side, wait a few minutes and trn it back on. Sometimes it won't even turn on properly and takes several attempts. Good picture, good sound, just won't stay on. Started happening when it was about 18 months old (checked timer - not the problem).
Http://en.allexperts.com/q/TV-VCR-Stereo-1749/2009/9/SP50L2HX.htm
Posted on Dec 01, 2009
Sharp 80le632u lcd turn off randomly & suddenly
Checked Power Board is it any solder is not proper. Resolder all main point.
Jun 04, 2017 | Sharp Aquos Televison & Video
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Water heats for about 3 seconds and goes cold
Take the cover off and look for reset that has trip.If you can't find no reset turn the power off and wait for five minutes,turn on and turn water on also to see if you get hot water.
Mar 14, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
A/c blows cold then goes to hot air
sounds like a vaccum diaphram may be leaking try listening for hissing noises under dash near the glove box,set blower to lowest setting\off if you can and still have a\c on.
Oct 07, 2008 | 1995 Volvo 850
Samsung HL-R6167W set turns itself off
sounds like the digital main board, seen this before
Jul 18, 2008 | Samsung HL-R6167W 61" HDTV
Battery, phone
theres a problem with its flash memory, you need to hot air solder the board and the flash IC chip on it. theres no problem with your battery. there maybe a cold solder around the chip.
Feb 18, 2008 | Motorola Mobility RAZR V3
Samsung PCK5315RX TV turns off
you tv problem is intermittent have a tech resolder you tv circuit.also have him check the power supply you could be having problem with the component there.probably the regulator diode or cap.good luck
Aug 01, 2007 | Samsung PCK5315RX TV
Tv powers itself on and off
You have a problem internally caused by heating (set is on for a few minutes) and then cooling (set turns itself off for a few minutes). Most likely a "cold solder joint" or a bad component on the power supply board. Locating it yourself can be difficult. If still under warentee you'll need to take it in or have them come out. (whatever is in your contract) They'll simply replace a circuit board instead of trying to fix it.
Jul 13, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
112 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
