1970 Oldsmobile Cutlass Logo
D
David Schech Posted on Jul 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my a/c blower only work on high speed. switch works and resistor good and get power through it.
Bill Boyd
Level 3:
Top Expert:
  • Oldsmobile Master 53,816 Answers
  • Posted on Jul 28, 2015
Bill Boyd
Oldsmobile Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949044
Points
172802
There is no resistor for high speed fan as it is full 12 volts
the slower speeds are resistor controlled
it should have a resistor pack in the blower housing ( air low to keep the resistors cool)
  • Bill Boyd Jul 28, 2015
    read that as air flow
2010 Chrysler sebring the heater isn't working. Changed the blower motor resistor and that didn't solve the problem. Took out the blower motor and checked it and it is working. I removed the insturment...
Use the test light and check for power at the resistor- one wire there would be for high speed, which basically bypasses the resistor.
Also check for power at the blower motor with key on and blower switch on high. If you have power and you know the blower motor is good, it could be a ground problem for the blower.
2helpful
2answers
Vw polo heater blower only works on full power
all speeds go through the resistor except high that is why it will work on high you are bypassing the resistor if you are sure the resistor is good it has to be the blower spped switch on the dash
Blower only works on high speed in 2003 focus
BLOWER MOTOR WORK ONLY ONE SPEED.YOU COULD HAVE FAULTY BLOWER MOTOR RESISTOR OR BLOWER MOTOR CONTROL SWITCH BAD.USE VOLT METER CHECK VOLTAGE AT EACH CONTROL SWITCH SPEED TERMINAL. IF POWER IS AT EACH TERMINAL ON CONTROL SWITCH YOU MORE LIKELY HAVE A BAD BLOWER MOTOR RESISTOR.
1helpful
My blower only will go on high and now its not working? but now its not working whats wrong i have no defrost or anything
Usually if your blower motor will work on high but not any of the other speeds then the blower motor speed resistor is at most likely fault. If the blower will no longer work at all you still may have a bad speed resistor but may also have a bad or corroded connector at the speed resistor or blower motor control switch, or even a blower motor that has finally failed. A blower motor that is pulling too many amps can damage the speed resistor, connector, and switch so I often also replace the blower motor whenever I find any of these other problems. Hope this helps and good luck!
1helpful
I would like to know how I can fix the heater in a 89 gmc k1500 with a 350 engine and no air. I tried a new heater motor and still not working. The Fuse is also good.
This is a blower motor not working tip I posted a little while back.
Blower motor problems are a pretty common topic. This is a basic guide on how to diagnose the problem and will work for most vehicles.
The diagram is generic and loosely based on GM's setup and more specifically a Silverado. Most manufacturers have a similar setup and the only major differences would be a ground side control (instead of the switch supplying power to the resistor it would be grounding the power from the resistor if this is the case you test light would need to be connected to power to test the switch) and late model Chrysler minivans (they use a module that looks for a difference in a/c voltage from the switch)
If the blower works on high only than likely the resistor assembly is the culprit since power to the blower essentially bypasses all of the resistors and/or the resistor assembly entirely. The reason why none off the other speeds will work is that the resistor or the circuit for the speed four setting has burned out. The lower the setting the more resistance you need to drop the voltage to the blower. The first speed setting requires all four resistors to drop the voltage enough to turn the blower at its slowest speed. Speed 2 needs to turn the blower a little faster so it uses three resistors. Speed 3 uses two resistors and speed 4 uses one.
In some cases the fan will work on high and speed setting 4. The likely cause for this is the speed 3 resistor or circuit has burned out. Speed 4 still works because it doesn't use the lower speeds resistors to control the speed of the blower. If the speed 2 resistor burns out than speed 1 and 2 will not work but 3, 4 and high will continue to work. If the speed 1 resistor burns out than speeds 2, 3, 4, and high will continue to work.
This leads us to how do we know if its the resistor or the switch or the blower. If the blower works on high than we know the blower works. That leaves us with either the switch or the resistor assembly (there are many other possibilities) which can be easily tested with a test light (or a voltmeter if you choose) The first thing to do is locate the resistor assemble. They can be behind the glove box, under the dash close to the blower motor or under the hood, again usually close to the blower motor. It will typically have 5 to six wires going to it. We'll start by unplugging the connector, turning the key on and connecting your test light to ground.
1.Turn the switch to high and backprobe all the wires. Two of them should illuminate the test light. In the diagram below this would be wire E & F. If you don't have a diagram then hold the test light on one of the two wires and move the switch to another speed setting. the wire that continuously illuminates the test light regardless of the switch position will be the constant power for high blower speed and will not need to be rechecked in the following steps.
2. Turn the switch to the next lowest setting. Backprobe the remaining wires to see if one of them illuminates the test light. Repeat until you have checked all of the speed settings.
3. If the test light has illuminated a different wire for each setting then we can reasonably assume that the switch is functioning as intended and the source of the problem is the blower resistor.
If you find one or more settings (but not all the settings) on the switch that does not illuminate the test light on any wire than we can reasonably assume that the switch has failed.
There are a few other things that can cause blower motors not to work as intended. The switch or the resistor assembly are the two most common problems.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
2answers
Heater blower works on high speed only. Manual
most likely ur multi-switch[fan selector switch] test out put for the other speeds if no output replace switch if good test motor
2helpful
2answers
Last week the heater blower motor stopped working on intermediate speeds and would only work on high. Today after working for a little while on high I lost all speeds of the blower motor. Is it the switch...
resistor for sure, the switch would have caused all speeds to fail as it only has one moving contact but the tapped wirewound resistor is a common part for this fault.
2helpful
Blower motor on 96 Isuzu Rodeo does not blow on any speeds, fuse is good. I read if blower motor on works on high only it is resister, and if works on all speeds but high is relay.. so does blower motor...
if fuses are good, check for power at blower motor, when truck is running and a/c on. the resistor and the switch provide ground, so the blue/white wire should have power, and the blue/black wire should have NO power, if it does have power, then most likely the resistor is bad. if it has no power and the motor doesnt run, the motor is bad.
1helpful
Blower motor doesn't work and has no power to it
Check the blower multispeed control resistor pack is not faulty.
The resistor pack is usually located in the air ducting, in the blower fan airflow.
Basically, +12v power is supplied (via fuse) to the fan speed control switch, which then passes via the selected speed control resistor, to the fan motor. Often a interface relay is used to switch the blower motor high current.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
