Question about Refrigerators
New fridge keeps dripping water from the
Bosch side by side fridge B20CS51SNS keeps dripping water from the dispensing tube how can i fix it?
  • mgma4 Aug 08, 2010
    Thats a great answer but, How do you get the panel off?
  • 50 Answers
Behind the panel of the dispenser there is an adjustment screw to adjust the microw switch If this does not fix it then the valve needs replacing Thatis usaly located in the bottom of the freg
Posted on Jul 12, 2009
B20Cs51SNS 02. Why is water dispenser dripping?
because the water control valve is defective it will need to be replaced
Appliance 911 Sea Breeze
Aug 18, 2015 | Bosch Refrigerators
Frigidaire water dispenser drips constantly. I have been told there is a main water valve and a second valve for the water dispenser. Where is it and how to replace?
if you are referring to the cold water on the door , then there is a solenoid valve on the bottom back left side of fridge, you will see two there , one is for ice maker and one is for water on door , most times it's a good idea to replace both of them , also there should be a filter inside fridge on bottom middle (cartridge) this should be changed monthly to maintain fresh taste and keep foreign objects out of tubes
Jun 01, 2015 | Frigidaire Refrigerators
Just installed a new Bosch fridge, ice dispenser dispenses ice but water does not dispense?
Make sure it has water on the container and no obstruction on the water dispenser. Try several times. Since it was new unit, sometimes water has not yet completely fill the dispenser tubing hence it will not dispense water.
Look for some carton, foam or plastic obstruction around the dispenser, it may cause hindrance of not flowing water from dispenser into the glass.
Thanks for asking.
Jul 03, 2011 | Bosch Refrigerators
I have a leaky spigot what can I do
If the spigot means the end of the water tube in the water dispenser, and it steadily drips even if the dispenser is not used for 10 minutes or so - replace the water valve. If the dispenser drips water mostly wright after you used it - you might have some air bubbles in the refrigerator water tubing.
Oct 17, 2009 | GALAXY Microsystems 25.4 cu. ft....
After using the water dispenser on my side by side ED20DF the water keeps on dripping? I've turned the water off for now, but I need to know how to fix it. Help??? Thanks
Could be couple of thing, but I think that first you need to check the connector. You open your refrigerator from both sides and then pull out the grille (don't worry it won't break) then if you see at your left there's a connector that put together a 5/16 water tube with a 1/4 water tube, try to fit both water tubes in the connector, maybe one of those is loose and that's the why of the dripping.
The other thing may be is with the mechanical-electrical interface, when you press the paddle, is you see the activation under the dispenser, it touches with a limit switch, maybe the limit switch is stuck with something when you activate or it is not working properly.
Also if you have a multimeter check the valve to see if it's not a problem with the signal that is coming to the valve, I mean if the problem is that even without press the paddle the dispenser start to dispense water.
Feb 19, 2009 | Whirlpool GS6NBEXR Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice/water dispenser drips after using
afraid that sounds exactly like the problem.brand new fridge call who you bought it from they should fix it for free good luck hope this solves your problem
Aug 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
No water from dispenser
Frig is set too low of temp Water is freezing in tubing chill coil
Jun 07, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Water Dispenser Drips
Had the same problem after replacing over seven water valves and installing a water regulator in the water line to the refrigerator with no help. Had to reduce the water pressure to about 27 pounds the reduce most of the drips. It drips an amount about the size of a quarter and when the water gets the coldest it stops the drip, but there is always a droplet at the end of the water disperser tube.
The problem is with water stored in the refrigerator side of the box. Water come in and does not leak. After the water gets colder it expands and oozes drips from the water dispenser. It is worse with the roll of tubing behind the crisper drawer on the bottom, because there is no room for expansion in the tubing. We replaced the tubing with and older style tank and it helped some, but not completely. The solution is 1. Try to buy a refrigerator with a tank instead of the roll of tubing in the bottom of the refrigerator side. 2. Don't use the water dispenser. 3. Reroute the tubing directly to the water dispenser and bypass going into the refrigerator, the water will not be as cold. 4. Avoid those built by Whirlpool.
Oct 04, 2007 | Hotpoint HSS25GFP Side by Side...
Water dripping from the water dispenser on freezer
If the water is dripping from the dispenser tube, you need a water valve. The valve is not shutting off completely. Check to make sure water is not dripping from ice chute. If the chute door doesn't seal off you will get moisture there and it will also frost up the ice chute.
Sep 30, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
237 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
