I cannot see a menu to review the settings, since the screen is scrambled. The PS3 is hooked up with an HDMI cable and worked int he past.
Hi April, Using the HDMI or the provided RCA jacks (red, white, yellow) any time you switch between the two you will need to perform a video reset on the system. It's the same process for all models. I am putting in a link that tells you exactly how to do it. ^^ Good luck, and I hope this helps.
How To Reset PS3 Video Settings PS3
SOURCE: unhooked ps3 from an hd tv and plugged it into an sd tv and it shows no picture.
you the man! that helped ssoooooooooooooooooo much!
SOURCE: Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
SOURCE: PS3 not working through HDMI cable
connect PS3 to TV
select HDMI channel on TV
press AND HOLD power button on PS3 until screen resolution selection page appears.
PS3 should now work.
had this problem, this solved it.
typical repairman looking for work :)
SOURCE: My PS3 recognizes the HDMI input, but when I attempt to change the settings, it won't work
welcome to fixya
you have to set it up on the ps3 for the cable
i had the same problem on the ps3 in settings there is hdmi cable set up make sure there set to hdmi and not to av wire
SOURCE: My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
