GE GSS25JEM Side by Side Refrigerator
Problem for GE GSS25JEM Side by Side Refrigerator
GE side by side; model # TFX25JRYD Serial #
By mouse8690 on Jul 12, 2009
GE side by side; model # TFX25JRYD Serial # AS256249: Ice make not getting water
Solution #1
posted on Jul 12, 2009
Somewhat Helpful)
woodchuck789
Rank: Guru  GE Refrigerators  Expert
Rating: 91%, 583 votes
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Was this helpful?
Yes
No
Popular Solutions for GE GSS25JEM Side by Side
Questions and Unsolved Problems for GE GSS25JEM Side by Side
Do you recommend GE GSS25JEM Side by Side Refrigerator?
Answer
Answer
we have had this refrigerator for over 10 years and it has lost temperature and started to defrost... (More)
Answer
Hi, Need to know what a control means for GE model DSS25PFMD WW. We know that the Defrost... (More)
Answer
defrost controls check good. main board reads 24vac to 32vac between j9 and j11 when jumping pins... (More)
Answer
Icemaker quit dumping ice, a load is frozen in the tray and when I removed the rear panel, the top... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
