Cars & Trucks Logo
v
verell Posted on Jul 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why won't it start?
Starter just makes whining noise Replaced starter, same problem
robert wales
Level 3:
  • Chevrolet Master 4,977 Answers
  • Posted on Jul 27, 2015
robert wales
Chevrolet Master
Level 3:
Answers
4977
Questions
0
Helped
1330608
Points
59541
Did you replace it with a new starter or a wrecker starter, maybe a bad starter. check the teeth on the flywheel they maybe damaged causing the starter not to engage. you may have to shim the starter. were there any shims when you pulled the original starter off.
3answers
2001 Sportster. Why does it make a whining noise as though starter is not engaging?
please add more details to your issue> like does the car engine run when you hit start ?
2helpful
2answers
1999 Pontiac Sunfire 5 speed won't start. Replaced spark plugs and checked ignition coil (fine). Sounds like it wants to turn over but makes a "whining" noise. Please assist. Thank you!
Is the engine turning over with the key in the start position? If the engine is not spinning over and you hear a whining noise, the starter is not engaging the flywheel. If the engine is turning over with the starter engaged, the engine has most likely jumped time that creates low or no compression which results in the whining noise.
2answers
I replaced my starter on my 94 ford ranger. my truck won't start, when it cranks, it makes a loud grinding noise. How can I fix this problem?
When buying starter motors it is essential that the starter pinion teeth are of the same pitch as the flywheel ring gear. Not all starters from the same make fit different engines because of this problem. However I would be checking that I had put the starter in the housing properly as any misalignment will cause your problem
94 GMC suburban whining noise
cudda been put in sloppy and irratating the crank--tell the mech hoo did it--some shops dont test drive n its bad biz
1helpful
Starter problems with my starter on a bmw x5. replaced starter and now all I hear is a whine from the starter, but vehicle won't turnover. what could be the problem.
sounds like the bendex in the starter is not kicking in take it to a local auto electrician and get him to check it out
Nissan pathfinder 1995 model SUV, when i try to start it its making a whinning noise then i hear a hard clucking sound and the whinning goes away without the car starting
Does the engine crank at all ?
The low whine could be the starter turning but not engaging the flywheel.
The clunk could be when the bendix gear on the starter makes contact with the flywheel.
If the starter does not have enough voltage, the solenoid or bendix may not engage. Even tho you replaced both the starter and battery, there could be a problem with the cables or the ground connection.
Trooper whines when you try to start it.
does engine turn over? sounds like maybe starter bendix problem. if starter whines but engine doe`s turn over replace starter good luck
3helpful
4answers
Just replaced a dead battery with a brand new one. Tried starting it and it makes a high pitch whining sound and wont start. Any suggestions of what the problem is? Does it need to sit to charge the...
The basics, your battery is used to provide power to the starter. Once the engine is running the alternator then provides current to recharge the battery and run all of your electrical components. so I would suspect the starter is not working to start the engine.
1helpful
Starter makes whinning noise on 97 camarro .battery is fully charged and starter tested positive at parts store.
Make sure that starter wears a condom.
If you meant that the starter makes a high-pitched whine but does not turn the engine, that starter is bad. More specifically, its drive (the "Bendix") is bad.
If the starter makes a screeching noise as it turns the engine, like it is working too hard and is irritated about the situation, you need to shim the starter. There are shims available at the parts store that fit around the mounting bolts, between the starter and the block. They are used to ensure that the starter drive gear teeth are not too close to the ring gear. If they are too close, the starter has to work much harder as it forces the teeth to mesh.
If you meant that the starter makes a whining noise for a short while after you start the engine, don't worry. Many starters do that.
If you meant that the starter makes a loud whine constantly after you have started the engine, it is staying engaged. It is either bad and that is the source of the problem, or there is another problem (like incorrect shimming) that caused it to stay engaged, and it is now bad. The same gear reduction that allows a small electric motor to spin a big heavy engine can work in reverse if the one-way clutch in the starter drive goes bad, and the high speeds that the starter guts would be subjected to if this happened would lead to self-destruction.
1helpful
The starter housing or bolts break whenever trying to start. I first had a problem with the starter making the whining sound that usually indicates the Bendix is bad. I took my 1996 Tahoe in to a local...
Wow it sounds like that they are not shiming the starter. On general motors products a new starter has to be shimmed, so that it lines up correctly with the flywheel. This is what is causing the flywheel/starter bolts to break and the noise you are hearing. Its not a hard process, just time consuming probably why it has not been done.
Sorry. Good luck! Dont forget to rate. Thanks, James
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
