Tappan air conditioner stopped working after taking the fiuse out for exteriror/siding work, then after I put it back the way it was, it did not work. No cool air or no fan. Please any idea would be appreciated. - I turned all the electrical controller off and on which did not help resolve the issue.
  • 50 Answers
Not knowingg the brand of fuse box Try looking at the holder where you grab it to see if it has any wording on it like power or service Some brands alow the fuse holder to be put in upside down for the service man to work on the unit If not have some one check the fuses to see if thy mite be bad
Posted on Jul 12, 2009
What is the problem hear blower and air conditioner stopped working
Sounds like an air lock in your heater system. Take off your radiator or expansion tank top and let your engine tick over while you fill up the water tank it may take twenty minutes before you feel warm air coming through your heater then put cap back on and run your engine normally
Jan 14, 2018 | Heating & Cooling
Why there is no cold air?
The compressor is not coming on and cooling the evaporator coils. It could be due to loss of refrigerant or something else.
Jun 05, 2014 | Everstar Portable Air Conditioner Everstar
My rheem air conditioner needed freon, but the tech stated it would not allow him to add enough to get to the correct psi
I think you need to have your unit properly evacuated and have a good vacumn drawn on it. If it was low on freon then it has a leak in it somewhere. If it is a small leak there are stop leak products that can be added through the suction side of unit while it is being recharged. If it is a very bad leak then it should be located and repaired. I would also put on a filter dryer on at least on the suction side.I prefer to put a dryer on both sides.If he can't make it take a proper charge then I would say that it has moisture and air in the system and it won't work right until they are removed and then recharged. Thank you.
Jul 29, 2011 | Heating & Cooling
We have a GWHD5000, it leaked water all over, my son and I drained it, but could not find where to put water into it? We ran it on fan only for awhile then put it on cool, the back off it heated up so I...
You do not put water into this air conditioner. It uses a special chemical inside of a system of pipes in order to cool.
The unit may get hot on one side, but that is due to how it extracts heat.
The water you experience leaking is condensation. I surmise you live in a humid climate. This is normal. Just watch where the condensation is leaking from.
If you are still having problems and it is not putting out cold or cool air, take it to an air conditioner repair shop or buy a new unit.
Hope this helped!
Thanks!
Jun 13, 2011 | Heating & Cooling
I have a delogongui air conditioner pacl90 and the air conditioner just is running with only a sign of FE THE REMOTE CONTROL WORK AND THE AIR CONDITIONER TURN ON WITH THE SIGN
According to the manual FE code means the tank is full. Open the cover on the rear of the AC, it is located at the bottom, Pull out the 2 drain hoses, take off the caps and let all the residual water flow out. Place the caps back on and put the hoses back inside.
Aug 12, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Stop button does not work on amanda quiet zone room air conditioner
hi there,
if the stop button doesn't work,it continously run you can shut off circuit breaker for emergency shuting off.if this a proramable a/c unplug your a/c and put it back wait for 15 minutes .and try to run if still doesn't work your holding relay is shorted from control panel,try to call a service technician to check the actual control panel defective.have a nice day,don;t forget to rate me,thank's a lot.
May 26, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Compressor Fan stop working
Do you have a meter? Either the fan is bad or the capacitor is bad. Ohm out the fan and then the capacitor. Be sure you take the disconnect out of the electrical box on the side of the house and or trip the breaker off. The capacitor is a dual run one side operates the compressor and one side operates the fan. I would really bet on the capacitor being bad. Have seen that a lot in my experience. Be sure to make note of the wiring of the capacitor before you take it out to check and if you are not sure how to check it take it to the parts house and they can check it.
May 17, 2009 | Goodman CKL24AR24 Air Conditioner
No air is coming through air ducts
filter could be stopped up on return air or coil frozen due to low charge
May 16, 2009 | Dometic Rooftop RV Air Conditioner
Air Unit turns on...compressor works, fan turns on and then shuts off?
Let me guess you drove it home on its side in your back seat and then plugged it in? Or like many stores with a surplus of product and limited space, there are some units that are stored on their sides by idiot employees, or ones that don't care they just want to get the freight put away. All of which will more than likely result in a dead air conditioner, refrigerator, or dehumidifier if the unit is not upright overnight before use. The refrigerant is also acts as the lube for internal parts and when stored improperly will all be located in the coils, and not in the compressor where it needs to be. You plug it in and the unit will overheat and die. Either that killed it or it was DOA, go back and exchange it. Why bother troubleshooting something you can exchange? If you did drive it home on its side don't tell them that, unless you are that guy who didn't put 50:1 in his lawn mower. Hack
Jul 12, 2007 | LG LB8000ER Air Conditioner
Heating & Cooling Logo
238 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
