Question about Air Tools & Compressors
I need the head bolts torque specs for an Ingersoll Rand t30 242-5c compressor .Just repalced valves and gaskets.
  • Anonymous Mar 23, 2014
    replace head gasket
  • 98 Answers
With Graphite gaskets the torque is 34 lbs.
Posted on Jul 21, 2009
Head bolt torque for ir. ss5 air compressor?
It's not that critical, use a torque wrench and make sure they are all evenly tightened like you would do with the head of a car engine. Use basic torque specs for the size bolt. That can be googled. Start with a lower setting on the torque wrench. Tighten the bolts in a pattern, then increase the torque setting and torque the bolts again.
May 20, 2016 | Ingersoll Rand Air Tools & Compressors
Torque on ahead bolt
the torque must use is 75ftlbs. that is for the air head.
hope can help.
Jan 30, 2014 | Ingersoll Rand - Rand Type - 30...
I would like the head bolt torque specs, just to retorque after startup
to be honest I always just snugged them down. Very seldom used a torque wrench. You need to check these often due to the fact that between the cylinders is a weak place for the head gasket. If you do blow one get you some garlock or similar gasket material and make a gasket. will work better and last longer.
Nov 27, 2011 | Ingersoll Rand SS5L5 Ir Electric...
SS5LS slow bulding pressure
typically on a ss5L5 the head gasket has gone bad. Disconnect tubing and remove the 6 bolts on the head . gently tap the head and valve plate. Mark these pieces before dis assembly for assembly. If you pick up both pieces as one , turn them over you will probably see a piece of the gasket missing at the smallest point between the 2 cylinders this gasket needs to be replaced. You can purchase a head and valve plate gasket or make the one you need if handy with tools. I've done it both ways.
Aug 29, 2011 | Ingersoll Rand Type 30 Fully Packaged Ir...
What is the torque for head bolts on my ingersoll rand ss3 compressor?
I can't say from their manual, but I've never rebuilt a compressor (and I check every one with the mfg) for which the head bolt torque isn't in the range of 25 ft. lbs. to 40 ft lbs. If you can't find it, torque to 30 or 35 and you've got it knocked.
Nov 25, 2009 | Ingersoll Rand SS3J5.5GB Wb Ir Portable...
Torque specs for the head bolts on a GMC compressor
There are surely specs, but you should be able to feel the right tightness for these bolts. It's when the threads just begin to bend-- if you don't know this feeling, and can't find the torque specs, use 15- 20 ft. lbs.
Nov 23, 2009 | Ingersoll Rand SS3F2 Gm Ir Portable...
I have a ingersoll rand air compressor rand 4000 60 gl vertical 230v model #ra5e6va serial #dc90177-0025 i am wanting to know what cylinder head torqe is for the compressor.the head gasket leaks oil and...
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Oct 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
AIR LEAKS CONTINUOUSLY OUT THE CRANKCASE VENT WHEN COMPRESSOR IS NOT RUNNING.
Sounds like a bad reed valve which are a part of the head gasket for a compressor. You can order the head gasket through IR or Grainger. But you need to have a Tech look at it. have a good day!
Aug 13, 2009 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
876 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Marvin
Marvin
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
