Question about Dryers
Element is staying off too long
Dryer is taking longer than usual to dry. on high heat setting, element comes on for about 50 seconds, but stays off for a little over 2 minutes. Air coming out vent ranges from 123 to 162 degreestested hi-temp thermostat with voltmeter: hooked my voltmeter wires to terminals on either side of hi-temp thermostat closest to front of dryer (the 250-degree thermostat); i see 220 volts when element is on, but goes to 0 volts when element goes off. Is that what's supposed to happen? i don't know if circuit breaks or if circuit engages when this thermostat does it's job - i'm confused. i don't think what i'm doing is proving anything...
  • 61 Answers
If you need a part www.appliancepartssolutions.com
Posted on Nov 19, 2009
    Problem Solver:
  • 6 Answers
Element should cycle a little longer than that i think 2 min then cycles high limit thermostat u checked could be reading wrong when its gets to certain temp that thermostat opens up so wont get so hot and catch on fire .. take thermostat is the smallest one is your high limit thermostat probably the one going bad
Posted on Jul 12, 2009
Whirlpool dryer times jump on high temp from 50 to 29 takes three cycles to dry cloths.
Check that the heating element is working. Then check the exhaust flue of dryer to make sure that it is not clogged. If it is the clothing will stay damp and the room housing the dryer will get hot and muggy.
Oct 27, 2016 | Whirlpool Dryers
My heating element stays on for about 15 sec at a time-is this normal?
Is is normal for the heating element to cycle on and off. The element is usually protected by an operating (or hi-limit) thermostat that helps regulate the internal operating temperature. The element is not supposed to stay on continuously or you could end up with a scorched clothing, or a fire hazard. As your clothes get dryer, the heating element should cycle less. As long as you are not having any problems with dryer performance, you shouldn't have anything to worry about.
However, if your dryer is heating, but you are experiencing longer dry times or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Mar 12, 2010 | Dryers
It takes longer to dry clothes than usual and the timer control is not moving or stays in one place
The timer is shot and the contacts are not moving so the heating element sensor will cut the heat off for saftey reasons which is equipt in dryers these days
Jan 24, 2010 | Dryers
My dryer does not get hot enough to dry the clothes.It takes about 80 minutes to dry on high heat.
If this is an electric dryer, it would appear that you have a broken dryer element, which would account for the extended drying time.
You can access the elements from the back of the dryer by removing the rear panel. Be sure to unplug the dryer first, to avoid getting an electric shock. You will need a multi-meter to check the continuity of the two (2) dryer elements. Just put the meter into the Ohms setting and check across the two element contact points to see if you have continuity. If you find that one of them isn't giving you a zero "0" reading, that is the bad one.
Go to searsdirectparts.com to enter in your full model number and you can see the exploded line drawing for your dryer and the parts list and prices for the replacement part.
The reason the dryer is taking longer to dry, is because without both elements, the dryer cannot get hot enough to dry the clothes within the normal time, as only one element is having to provide all the heat in an attempt to dry the clothes.
You should replace the element as soon as possible, as having only one heating element working will cause that remaining element to fail sooner as well, since it will be staying one for a much longer time than normal.
Hope you find this Very Helpful and best regards!
Aug 26, 2009 | Dryers
Dryer element stays warm
If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
May 16, 2009 | Maytag MDE2600 Electric Dryer
Hello my Kenmore Dryer is working fine although taking alot longer to dry the clothes. I took everything apart and clean it, no vent blockage, and great air circulation through dryer. I was wondering; is...
THE ELEMENT CYCLES. NO IT DOESN'T STAY ON THE WHOLE TIME, BUT IT SHOULD BE ON FOR MORE THAN A BRIEF SECONDS TOO. POST ME THE MODEL NUMBER FOUND SOMWHERE AROUND THE DOOR AND I'LL HELP FURTHER. THERE ARE THERMOSTAT/S HIGH-LIMIT SHUT OFF SWITCHES AND IF THEY ARE NOT FUNCTIONING PROPERLY IT WILL CAUSE DRYING TIME PROBLEMS
Apr 11, 2009 | Dryers
Takes a long time for clothes to dry.
You have a bad element, these are fairly cheap and easy to replace.
Dec 27, 2008 | Frigidaire Dryers
Estate Dryer 840 jq2 takes forever to dry our clothes.....
Is outlet holding plug good and tight (assuming this is electric as you say heating element). I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Estate TEDS840JQ Electric Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Crosley Dryer Heats then stops
If im thinking right, this dryer has the element in the top left corner.  This unit has two thermostats, one mounted right above the element, and the other in the lower left front mounted on the fan housing.  The one in the front is called the high limit thermostat, which means when it gets to a preset high temp, it cuts off the system until cooling occurs.  The top thermostat, mounted above the element is the operating thermostat.  It probably is one of the two thermostats.  Its a very good idea to replace not only both of the thermostats, but the fuse as well.  The fuse kit (Maytag Part# LA-1053) comes with a thermostat and 2 fuses, be sure to follow he instructions on how to determine the fuse for electric and gas.  The high limit thermostat (Maytag Part# 53-0771) is an easy replacement.  Something is causing the unit to short cycle.  Sometimes you can hot-wire the operating thermostat (use caution, severe caution if doing this, not recommended if you arent sure whats going on).  By doing this (removing the two wires from the thermostat, taping them together), you can watch and see if the element stays on longer, at least until the high limit switch comes on.  This is really not recommended, if the high limit is out, it will not be good.  Just easier to replace them both.
Oct 24, 2007 | Crosley CDE6000 Electric Dryer
Dryers Logo
66 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
