Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Vertical line on right side of screen, varies in intensity
Recently changed to verizon fios from cox cable. it showed up
on cox very rarely recently. it is on verizon on all channels.
    Sergeant:
    Champion:
  • 249 Answers
Picture tube problem
Posted on Jul 12, 2009
Remote code for rca 50 in lcd 50lb45rq
For Universal Remote Control brands listed below, please use accompanying codes and refer to your Universal Remote Control UserManual for basic Instruction for changing TV code to operate the TV model.
Codes for DIRECTV: 0178, 10178
Codes for Time Warner Cable: 0178, 10178
Codes for Cox Communications: 0178
Codes for Comcast: 10178
Codes for Dish Network: 627
Codes for Fios Verizon: 0205, 0057, 0493, 0775
Jun 30, 2012 | Televison & Video
I just changed from Comcast Cable to Verizon Fios. Since the change I am unable to get a full picture on Fox News. There is a narrow horizontal picture with 1-2" black bands across the top and...
This is a function of your set-top box (STB), and has nothing to do with the TV. I know several FiOS users with the same trouble, and it's annoying but there isn't anything you can do to "fix" it. What is really strange is that the screen size can change even on the same channel, depending on the particular program being broadcast. It has to do with the aspect ratio of the programming from the provider.
Jan 12, 2011 | Panasonic CT-32G23 32" TV
I got a hd box and the channels keep cuttin out
Hello, I actually install HD boxes for Verizon Fios. If your video signal is too low, you will notice "Pixellation" (Those weird square boxes that come and go) and in some cases, you will not even be able to receive some channels at all. HD channels use much more bandwidth than standard definition channels. The good news....there's a fix. If you use standard cable (Not Fios) you can buy a signal booster. These can be purchased at best buy, Radio Shack, etc. It is a powered device that plugs into an outlet (110v) You take your cable company's input or "Feed" run it into the booster, connect the power, and the run a coax cable out of the booster and into your splitter. Assuming all of your cabling is up to par, this will fix your problem. If you have Verizon Fios, you must call and have us come out as our tv service uses "Moca" and cannot be boosted with a store bought unit. I hope this helps.
Jan 03, 2011 | Televison & Video
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Can it be used like any other tv (cox,dish net
Yes, We have Verizon FIOS now. Set it up with Aux 1 or 2, using the red, white and yellow cables. It will work, but you may need to find a way around the remote issues. My Fios remote does not turn it on or volume control, so I have two remotes, working on a solution to that one!
Sep 26, 2009 | Humax LD2060 20 in. EDTV-Ready LCD...
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Sep 21, 2009 | Dell Inspiron 1525 Notebook
Ittermittent digital audio drop out on some channels
Did the issue ever get resolved. I have similar issues with a connection to Cox Cable HDTV and Onkyo TX-DX989. All sources (DVD Player) sound fine and not issues except channels 706 and 710 on Cox Digital receiver. I had Cox replace the HDTV receiver and the same issue occurs. I've tried optical audio and also the COAX audio ports with the same issue. The workaround I have found is to set the audio to "Other" on the Cox box, but the volume then has to be turned up quite a bit.
Jan 16, 2009 | Onkyo TX-DS989 Receiver
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
219 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
