If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: Vertical lines and big red spot on Panasonic PT-56LCX66
Return it my friend, it sounds like a problem on the display panel driver board, and boy is that expensive to replace! Good Luck
SOURCE: vertical green lines
Call where you bought the TV. This is not normal for an LCD TV. They should exchange it only being a week old.
SOURCE: Vertical lines on Panasonic DLP
panasonic hdtv 1080i has a rainbow in the middle and shows shadow
SOURCE: my panasonic tv pt-47wx51e color looks like 3d how
There is a convergence kit available for your model which contains the new ICs and resistors plus the instructions of how to install the repair kit on CD. Heres a link look under Panasonic repair kits and you will see your model listed.
www.tvrepairkits.net
SOURCE: Vertical lines across screen on my panasonic tv PT-61LCX65
Try setting a portable fan aimed toward the cooling vents on the back of the set. If this eliminates or reduces the occurance of the lines, this means a circuit that controls the off/on of individual pixels has developed a thermal problem. This circuit is ordinarily loacted on the main circuit board and is likely to degrade further. You might inquire at the Panasonic service center if they have an exchange program in place and they will probably be able to confirm my suspicions.
