Question about Compaq Armada 7400 Notebook
BOOTING FROM CD ROM DRIVE
I WANT TO BOOT FROM CD ROM DRIVE IN MY COMPAQ ARMADA 7400 LAPTOP TO ENABLE ME LOAD WINDOWS XP ,MY CD ROM IS IN THE DRIVE ALREADY AND I DONT KNOW THE KEY TO PRESS ON MY KEYBOARD.
  • ed2rosa Feb 25, 2008
    I erased my hard drive with killdisk and partition and reformatted it. I tried installing windows 98 but it will not install claiming another version is on the hard drive.
  • 883 Answers
Try typing:
D:/SETUP
don't forget the colon after D
if this does not work, then try typing:
E:/SETUP
Posted on Nov 15, 2007
NTLDR compressed on a Compaq Presario SR105CL cant enter bios to set to boot
Step 1:
Which operating system ?
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT.32 New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. b> Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer. If you are attempting to BOOT from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt. If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt. Press any key to boot from the CD
Mar 10, 2013 | Compaq Presario sr1055cl PC Desktop
NTLDR is missing
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file..
  5. Corrupt boot sector / master boot record.
  6. Seriously corrupted version of Windows 2000 or Windows XP.
  7. Loose or Faulty IDE/EIDE hard disk drive cable.
  8. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable CD-ROM. First verify that no CD is in the computer, unless you are attempting to boot from a CD.
Nov 29, 2011 | HP Compaq 6710b Notebook
How to Install WinXp in Vista Platform
There is very simple procedure.
  • 1st restart your Laptop and enter in bios setup with the help of F2 key or F1 or Del key.
  • After entering in BIOS setup change the Boot order or Boot sequence.
  • Select the booting device 1st boot from CD Rom.
  • Save the setting.
  • Insert windows XP Cd in CD Rom.
  • Now Computer start from CD Rom.
  • You follow the instruction and install the windows.
  • Compaq Notebook Drivers
Mar 20, 2010 | Compaq Presario Notebook
Wireless card for compaq armando 7400 laptop
Any wireless card (PCMCIA slot or USB) will do provided a Windows 2000 driver is available for it. Unlike Windows XP and Vista where a built in wireless manager for the OS can be used, you must use the wireless manager that comes with the driver cd for your card. As for wireless type, Get either WIreless G or N. You can use Wireless B, but you get better range and throughput with G or N.
Mar 24, 2009 | Compaq Armada 7400 Notebook
Drivers and utilities
Download compaq armada 7400:
File name: compaq-armada-7400-driver.2.5.3.zip
File size: 58 KB
Downloaded: 5516 times
Posted by: Heironious
Nov 23, 2008 | XFX GeForce 6200TC Graphic Card
How to install operating system on laptop with now cd-rom drive or floppy
Did you change the '1st boot' drive to the optical drive?
If you haven't, you need to enter the BIOS setup and change from C: to whatever your optical drive is named and then change it back once the operating system is installed on the C: drive.
Oct 11, 2008 | Compaq Armada E500 Notebook
Non-system disk or disk error
Is you cd-rom drive shot - are you trying to boot up your computer through an xp or windows cd? If it is, it's not going to recognize and boot up. You'd be best getting a new drive - look around for someone with a Compaq Evo 800cp. They have the same exact cd-rom drive. Here are your compatible cd-rom devices:
TEAC DW-224E-A
or a Compaq DVD-ROM DRN-8080B
otherwise try a HP SD-C2612. I have these three drives. They all work really well.
Jul 01, 2008 | Compaq Armada E500 Notebook
Notebook won't book from CD
could you start setup from windows? if you can, do that. but the not booting from CD problem, it might just be the cd cause that's happened to me where certain cd's won't boot.
May 04, 2008 | Compaq Armada E500 Notebook
Boot cd-rom type:cd-rom/non-emulation booting
No, it's because Microsoft changed the way boot CDs work with SP2. You need an old CD (Windows XP SP1). I had the same problem here, notebook without floppy, it won't boot from the newer XP version CDs (SP2 or SP3) - but an old SP1 CD works!
(Those were all original Microsoft CDs, and the SP2 / SP3 CDs boot just fine on several other PCs I tested. It's just that some old hardware has a problem with the boot mode used on newer Windows CDs.)
Sep 20, 2007 | Computers & Internet
Boot sequence problem
try booting to DOS screen only by inserting a boot-able floppy disc (I use Win ME disc at this point although my system is also Win XP). Then select "boot with CD-ROM driver". It will detect your CDROM drive and assign a letter. Now insert the CD and boot from there. I have done this sequence many times with no problems.
Jul 13, 2007 | Compaq Armada E500 Notebook
Compaq Armada 7400 Notebook Logo
175 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
