My Armstrong Concept 1000 5ton stopped running outside. I reset the breaker and now it's blowing warm air. The copper line in is luke warm, not cold. Please help, TIA
  • Lamar Rains
    Lamar Rains Jun 05, 2015
    Did u figure out what happened I'm having same issue.
    Scholar:
  • 91 Answers
Sounds like your low on refrigerant, presuming your compressor is coming on at all. Listen for a distinctively lower toned motor running other than the fan motor. Either problem necessitates an EPA certified Tech for a fix. Good luck
Posted on Jul 12, 2009
  • rjaram Dec 26, 2010
    REPLACE RUN START CAPACITOR TO COMPRESSOR MOTOR INSIDE PANEL,THEN
    LATER PURCHASE EQUIVALENT MOTOR FROM SEARS OR ANY HVAC SUPPLY, YOU
    CAN EASILY GET MOTOR SPECS RIGHT FROM THE MOTOR ONCE YOU DISASSEMBLE
    THE FAN, GRILL, ETC. MAKE SURE BREAKER IS OFF FIRST. CAP IS INSIDE PANEL,
    FOLLOW WIRES FROM MOTOR TUBE TO PANEL, JUST UNPLUG BLADE CONNECTORS,
    LABEL YOUR WIRES!! THE CIRCUIT DIAGRAM IN THE PANEL IS USUALLY RUINED,
    REMEMBER CAPS WILL STORE A CHARGE SOMETIMES. ONCE CAP IS REPLACED,
    THEN RESET BREAKER AND RESET THERMOSTAT IN THE HOUSE, THE MOTOR
    SHOULD START WORKING, YOU'RE DONE. IF MOTOR SQUEALS OR DOESENT
    WORK PROPERLY, CHANGE TO A NEW MOTOR, THEY ARE LESS THAN $100.00.
    CAP SHOULD ONLY COST YOU $20.00 MAX.
Why does my ac not blow cold air?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds After you turn it back on the system should reset. If you need any other assistance check us out online at Boca AC Service we are always happy to lend a helping hand
May 26, 2016 | Heating & Cooling
Why does it just blow cool air?
Check outside condensing unit. Should feel warm to hot air blowing out of the top. If cool to outside air temperature blowing off you likely have a refrigerant problem
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 02, 2016 | Heating & Cooling
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Why does the compressor run only for about 5 minutes then shut off, leaving the fan still running?
It seems that you have a system short. You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
If this doesn't help I would recommend calling a ac service company.
AC Repair Coral Springs
Apr 24, 2015 | Heating & Cooling
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
Apr 19, 2017 | Heating & Cooling
The outdoor Armstrong Concept One central A/C stopped running. We had a brief power failure yesterday. The motor stopped. I went outside and found the box with a black plastic handle that says on/off but...
The black plastic box is a pull-out disconnect. The more likely source of your problem is the breaker that feeds this disconnect. See if it is tripped. If so reset it.
Sep 03, 2011 | Heating & Cooling
My Armstrong Concept 1200 stopped working yesterday (model EFC14MAA-1A, Serial # 6099F44101, 42000 BTUs). All breakers are OK. On the outside compressor unit, I can depress the relay and the fan and...
sounds like your problem is in the air handler. Sounds like the fan is not kicking on in the air handler this could be the board or the cap or fan motor you can run a micro farad test on the cap that goes to your evap motor be sure you take the leads off the cap and the mf are written on the cap itself. does the outside suction line which is the big line starting to freeze up? you can check your motor winding by running an ohms test across the motor winding. You do this by reading on the motor which wires goes to your start and run windings. You should get and ohms reading and if they are bad you will get infinity.
Jul 31, 2011 | Heating & Cooling
I have a trane xe 800 its blowing air but not cold air, i felt the copper/bronze tube running into the unit it is luke warm also no chill at all. where should i start checking to get my house cold again.
Hello, if the pipe with insulation is luke warm then either the unit is empty of refrigerant due to leak or the compressor is not running at all. Start by going tje the outdoor unitnand checking if the compressor is running, if it is then the unit has no refrigerant, if the compressor is not running then either a bad capaitor orbthe compressor itself might be bad.
Jul 20, 2011 | Heating & Cooling
Blowing luke warm sometimes and hot others
you have a bad breaker and need to replace it. when you put the load all on one you are taking a chance on having to replace both of them. Thae are not made ot be shut off and on to manty times.
Jan 21, 2009 | Heating & Cooling
Heating & Cooling Logo
1,651 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
