Question about Whirlpool AWZ410 Front Load Washer/Dryer
Today spin cycle was very loud and noisy so I stopped and removed the wash and found large tear in inner drum, any idea what caused this and can it be repaired
SOURCE:
  • 249 Answers
SOURCE: Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Posted on Dec 17, 2007
Lumpy816
  • 246 Answers
SOURCE: loud noise at end of spin cycle
The most common cause of the symptom you are describing is a bad drive block which has probably ruined your basket drive as well. Let me give a quick explination. The weight of the basket you put your clothes in is supported entirely in the center of the washer underneath your agitator. It rests on an aluminum block called your drive block. So that the basket will move back and forth while the washer agitates, there are two tabs on the drive block that lock your basket drive underneath in place. Once the drive block wears out or round down these tabs, the basket will raise slightly and "skip" across the top when the spin cyle is stopped. To verify this, you can check one of two things. First (and easiest) is put a heavy, large load in the washer, get it wet then spin it out. Once the washer reaches the maximum spin speed, open the lid. The washer should snap to a halt when functioning properly. What I belive you'll find is that even with the lid open, the basket will continue to spin. The other method to verify this is take the top of the agitator off. Next remove the bolt in the middle of the agitator and lift the agitator off. In the middle, you should find a large flat metal colored nut.In the middle of that nut, you should see two tabs across from one another. There should be two straight pieces of metal coming up from the bottom which have nice, straight sharp corners. Again, if I am correct, you will find they have been rounded off and there may even be shavings of metal visable.
To replace a basket drive and drive block, you will need to purchase the parts and also a specialty tool from removal and instalation. These will probably run you around 125-175. If you are interested in giving it a go, reply back to me and I will get you some step-by-stpe instructions typed up.
Posted on Jun 26, 2008
futureloginn
  • 734 Answers
SOURCE: Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Dec 12, 2008
  • 2976 Answers
SOURCE: Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Posted on Feb 02, 2009
onthejob5130
  • 640 Answers
SOURCE: spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
Posted on Feb 07, 2009
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Hotpoint aquaries wf321 is making a loud clicking/knocking noise when its in the spin cycle, to me sounds like a poss bearing gone or maybe something is caught up?
From the front of the washer, spin the drum by hand, if it feels rough or is noisy or rumbling, then the drum bearings have failed.
It is possible that there is something caught between the inner and outer drum.
Nov 30, 2010 | Hotpoint Washing Machines
When on a fast spin it is extremely loud, too loud...
Water in bearings causes rust, and rust in bearings creates noise...This is the most likely reason for the noisy spin....Check for any slop in inner drum....Bearings and seals and likely the shaft probably need to be replaced....Quite a big and complex job....Good luck....Nomess
May 18, 2010 | Washing Machines
Cause of noisy spinning
your drum bearings have gotten water into them from a defective inner drum lip seal,now you need to tear down the machine and replace the lip seal and also replace both inner and outer drum bearings
Apr 18, 2010 | Zanussi ZWF1430W Front Load Washer
Very Loud banging on washing machine spin cycle
Ah,,,,Sounds like drum bearings havee gone the circles iassume is oil from the bearing it will be very noisy on spinen and a lot of play on drum ..quite a big repair..hope you get on ok
Sep 30, 2009 | Washing Machines
Loud spin cycle/water leaking
If your washer is making a "freight train" like noise in the spin mode, ( loud roaring ), this is often the spin bearing built into the bottom area of the transmission that is worn out. This bearing is part of the transmission and means a new transmission is required. The noise is usually a result of water leaking from the center seal and bearing area onto the transmission. This water washes out the bearing and it gets very noisy in the spin cycle!! Do check the easy stuff before condemning, nail/pin caught in one of the inner basket holes, nothing is caught in the drain pump, the inner wash basket is not loose and wobbling around.
Jan 14, 2009 | Kenmore 44102 Front Load Washer
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Very Noisy Washer!
Hello julierealtor how old is the washer? Try turning the inner drum by hand and see if it is noisey or moves up and down. If so then it is either your rear support of the inner drum that has failed or the rear bearings. If it seems fine, maybe you have something in the drain pump (which runs prior to and during the spin) that is causing the noise. If it is noisy during the drain, then you may either need to clean out the pump or replace it. Hope this helps.
Aug 10, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Noisy
usually a noisy machine means either the main bearings have gone or the motor has got damaged/worn in some way. to check the main bearings try lifting the drum with the hand from inside or rotate the drum with the hand to see if the rumble can be felt. i cannot think what else would cause a loud humming though.
Jun 11, 2007 | Zanussi FJ1454W Front Load Washer
Noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Feb 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool AWZ410 Front Load Washer/Dryer Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
