I have the same problem, but there is a full line to the right of EVERYTHING. There is a light grey line or trail, extending off of the end of every image on my screen.
im having the same problem even now i cant even play fullscreens games anymore if it had to be played fullscreen i had to pull the power wire from the back of the monitor and re put it back aftert 30 or 20sec than it appears so i can play in game its the same when im exiting a fullscreen game please find a solution to this my eyes can go blind if i continue seeing this drop shadow continuosly
AnonymousNov 11, 2008
Me tooMe too
AnonymousNov 22, 2008
same problem - it's driving me crazy - anybody know of a way to fix this? same problem - it's driving me crazy - anybody know of a way to fix this?
same problem , a kind of shadow which looks like out of focus after it runs a while , a sharp rap or slap on the side of the monitor about half way often corrects it for a while..20-60 min. where to start to fix this?same problem , a kind of shadow which looks like out of focus after it runs a while , a sharp rap or slap on the side of the monitor about half way often corrects it for a while..20-60 min. where to start to fix this?
AnonymousFeb 05, 2009
Exactly the same here
You can't post conmments that contain an email address.
Shadow after text is usually caused by an impedence or termination issue. If you have a multimeter, check the VGA connector pins 1 2 3 (R G B) vs GND should be 75 ohms. If not, cable is damaged or poor quality. Try a new VGA cable, should cost $5+
If the edge of the text is wavy, there is too much jitter in the signals coming from the graphics chips. No fix possible.
If the edges of the characters are lumpy, then the panel has a cheap A/D converter, try using it in DVI mode instead (white-white connectors instead of blue).
Go into settings a restore to defaults.
Then right click on desktop and then display go to display driver and restore to default or uninstall reboot computer and it will reinstall the drivers.
Following site appears to have installation and setting instructions, Aug 2011 http://www.lelong.com.my/shadow-sw-1301-mini-auto-turbo-timer-taiwan-K856367-2007-01-Sale-I.htm To make a pdf manual using word7.0, right click and copy each image odd website above, paste image into word document, add text as needed, when complete, go to save as, select pdf in drop down menu for file type.
same exact thing
same thing shadow after text
Me too
